Like Tree9Likes
Old 11-21-2011, 09:46 AM
  #24601
dtr
dtr's Avatar
Originally Posted by buckeyenut73
new to rc without reading 1600 pages what do you guys use to clean old diff oil and junk out of diffs when rebuilding and re oiling diffs?
Brake cleaner spray.
dtr is offline
Old 11-21-2011, 10:00 AM
  #24602
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Originally Posted by EricInNeenah
are you running at 27mm ride height or below? I had to get the new tuning spring pack to achieve 27mm in the rear..i think with the stock springs you can get 28mm with the collars all the way up. I followed the the dakotah phend setup , and my scte corners much more planted instead of skipping through turns or traction rolling
hacker: are you guys trying anything new on the scte setup for Trackside?
Good point, lowering the truck would help keep it planted in the high speed sweeper.
Can you post a link for the right spring?
kjohnsiii is offline
Old 11-21-2011, 10:15 AM
  #24603
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Which tires are you running? I had a traction roll problem when I ran Enduros. Someone I race with suggested going to a rounded profile tire like the stock Eclipse or BowFighters. Since I swapped tires I have traction rolled nearly as much.
Originally Posted by kjohnsiii
Can someone help please. I am running on a high bite track and trying to dial out some side
Side bite out. I keep traction rolling.
ChrisAttebery is offline
Old 11-21-2011, 10:28 AM
  #24604
R/C Tech Elite Member
JayL's Avatar
will the new HA ball end kit include the steering ones or will we need this as well:?
http://www.amainhobbies.com/product_...ering-Link-Set
JayL is offline
Old 11-21-2011, 10:34 AM
  #24605
Default WTB: Clean Roller.
Hey Guys,
I'm looking for a clean SCTE for my son. If you're thinking of selling your truck please let me know.
Thanks,
Chris
Old 11-21-2011, 10:47 AM
  #24606
kjohnsiii's Avatar
Running the bar code golds, which are on the flatter side. I think I will try lowering the truck first.
Chris
Old 11-21-2011, 11:02 AM
  #24607
racerx1920's Avatar
Trader Rating: 218 (100%+)
i dont know if this has been asked or not but is anyone useing this for there stearing?
http://www.amainhobbies.com/product_...ering-Link-Set[/QUOTE]
racerx1920 is offline
Old 11-21-2011, 11:34 AM
  #24608
Trader Rating: 62 (100%+)
thank you chucko and dtr.
buckeyenut73 is offline
Old 11-21-2011, 11:58 AM
  #24609
EricInNeenah's Avatar
Default springs
http://www.losi.com/ProdInfo/Files/L...atChampion.pdf
using the aluminum hinge pin holders set at 2 degree rear toe in instead of the stock 3 helps free up the rear end instead of binding in the corner and flipping , its everything used together to make the truck work in harmony,i followed my setup exactly as Dakotah's except for I used Dustin Evans piston and oil selection http://www.losi.com/ProdInfo/Files/L...Rd2.pdfinstead, because i run indoor clay,
EricInNeenah is offline
Old 11-21-2011, 12:09 PM
  #24610
ae-Dan's Avatar
Trader Rating: 39 (100%+)
[/QUOTE]
yes its a perfect fit and its got hard balls
ae-Dan is offline
Old 11-21-2011, 12:25 PM
  #24611
racerx1920's Avatar
yes its a perfect fit and its got hard balls[/QUOTE]
awsome thanks ill be getting one
Old 11-21-2011, 12:29 PM
  #24612
KingdomRacer's Avatar
using the aluminum hinge pin holders set at 3 degree rear toe in instead of the stock 4 helps free up the rear end instead of binding in the corner and flipping , its everything used together to make the truck work in harmony,i followed my setup exactly as Dakotah's except for I used Dustin Evans piston and oil selection http://www.losi.com/ProdInfo/Files/L...Rd2.pdfinstead, because i run indoor clay,
I thought stock rear toe is 3 degrees.
KingdomRacer is offline
Old 11-21-2011, 12:38 PM
  #24613
Default inserts and toe in
yea youre right , just to make sure they use the right inserts to be at 2 or 3 degree and not 4 degrees, 3 degrees antisquat in the front inserts too
http://www.tlracing.com/ProdInfo/Fil...tallation3.pdf
Old 11-21-2011, 12:57 PM
  #24614
RC*PHREAK's Avatar
Trader Rating: 146 (100%+)
Originally Posted by ChrisAttebery
Hey Guys,
Thanks,
Chris
NICE!! I see some podium finishes in Jacob's future!
RC*PHREAK is offline
Old 11-21-2011, 01:44 PM
  #24615
After the last race there was no way I could deny that a 4wd would be better for him.
