Like Tree9Likes
Old 10-04-2011, 11:05 AM
  #21496
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by Casper View Post
Hard track with a little dust you guys try orange barcodes? They arn't going to last as long but taller pins will tend to fold and give inconsistant handling and traction rolling. A harder front tire will slide more and grab less and this might help as well.
Originally Posted by ChrisAttebery View Post
I was running Orange BarCodes for a few weeks but with the extra dust lately I thought a tire with a bigger pin would dig down through the dust to the hard pack.
Thanks for all of the great ideas guys. I'll have a few tricks to try out this weekend.
i like the rebars on the big track. i have mixed and matched and found that slightly worn rebars on the front with new ones on back is a nice combo.
RC*PHREAK is offline
Old 10-04-2011, 11:14 AM
  #21497
Bondonutz's Avatar
Trader Rating: 48 (100%+)
Originally Posted by coffee View Post
I know some of you like the extra weight of this truck, but I am having a hard time making ten minutes on a 6000maH battery. I have a heavy trigger finger, there is no doubt about that. But how light has anyone been able to get this thing so far? I have been shopping for light weight parts, but I am wondering just how much a difference it can make on this chassis.
I have my indoor SCTE down to 5lb 8.6oz race ready
http://hdrcvideos.com/forums/viewtopic.php?f=16&t=22211
Bondonutz is offline
Old 10-04-2011, 12:46 PM
  #21498
chucko's Avatar
Chrisatabery. here in oregon where i'm at. I have been running 3 different tracks, all different. all loose, lomey, & wet, big track huge jumps. you can see them on northwest tracks here or facebook.. santiam, medford, bend, my set ups for loose are...caliber tire's rear to gridirons super soft front adjustable shims for arms front and rear front at o's.... front o front back 2.5 rear rear. orange springs front,. black rear, drupe at 93 mm front 103 rear with 20 oil front 25 rear,,top out side shock mount,. arms out side, front end shock mount I have 4 adjustments on cf towers and am @ 3 top, arms inside.. running a grease in all my difs. I am using pro long oil mix and grease together after gluing all my diffs. Been running 4 poll tekin rx8 14 and 13 pin. 4600. 6200 mah 60C pro match. 2 cell. 0 timing. tame as it can get to on the speed control. you know how the boys say at losi it gets better after its run and loose. make sure your arms are loose..... also running large 2.5 say bar in front and 1.5 rear...for any body else this is my set up and it works for me. the only thing I change from track to track is shock oils' Tires... try it you might like it.. Now if I could last a race without burning up my electronics,... I would be first not 2nd in points...
added picture of 1 of the tracks in Bend
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-pano.jpg
chucko is offline
Old 10-04-2011, 01:04 PM
  #21499
Default CENTER DRIVE PIN RETAINING RINGS
GUYS ,
I have been made aware that the center drive pins are wearing through the
plastic covers.
This was the same problem we had on the Losi 1.0 model.
This simple fix worked great and was very reliable.
simply remove the plastic cover.
slide the ring over the retaining pin.
cut the schrink wrap to cover both the front pin and the set screw.
this will retain the ring and the drive set screw.
Simple and effective.
part no. M2C7111
replacement schrink wrap part no. 6076
www.m2cracing.com
m2cracing is offline
Old 10-04-2011, 01:43 PM
  #21500
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by m2cracing View Post
GUYS ,
plastic covers.
part no. M2C7111
www.m2cracing.com
and only $14.98, nice! Comes with the shrink wrap or no? Can't find it separately on your sight. Also it's the losi SCTE, not the SCT10, might want to change that.
lowroad is offline
Old 10-04-2011, 02:19 PM
  #21501
DBL15's Avatar
ok guys been looking and reading this thread alot but i have a question
i started iinstalling my TLR tuning kit last night and
there is a heap of front and rear black rubber grommets that go into the pin holders
i just put the ones marked with 0 in the front and back should i have done that ? of what numbers should i have used front and back ?
must say the TLR chassis is very nice as well
DBL15 is offline
Old 10-04-2011, 02:30 PM
  #21502
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
0 Degree blocks will give you the "stock settings"
BashemSmashem is offline
Old 10-04-2011, 02:34 PM
  #21503
DBL15's Avatar
awesome just how i wanted it but i honestly was not to sure
thanks for your help mate cheers
DBL15 is offline
Old 10-04-2011, 02:53 PM
  #21504
No prob happy to help ...
Old 10-04-2011, 03:02 PM
  #21505
SaladFork's Avatar
VX4's will be here tomorrow... trucks are all ready for the installs. Going to the track for some testing and video.
SaladFork is offline
Old 10-04-2011, 03:13 PM
  #21506
lowroad's Avatar
even the vx4R?
lowroad is offline
Old 10-04-2011, 03:24 PM
  #21507
chucko's Avatar
I have tried spit, wd 40, vaseline, sex cream, LOL I can't seem to save those silly little rubber boots on the shocks. what's the secret ? to changing springs and oils with destroying them PLEASE ? Thanks
chucko is offline
Old 10-04-2011, 03:36 PM
  #21508
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
Use all of the lubes mentioned above for their intended uses and throw the boots in the trash.
alvinsmith75 is offline
Old 10-04-2011, 03:47 PM
  #21509
X2
dany5 is offline
Old 10-04-2011, 03:50 PM
  #21510
X3 or just keep buying them
