Like Tree9Likes
Old 10-21-2011, 11:25 AM
  #22996
Zamboni's Avatar
Originally Posted by D.a.v.e
I'm an oddball but am running 30,000, 30,000, 10,000 and found the Losi Strike tires hook up pretty good on our small carpet track.
Dave your not alone on this one, well for the tires anyways. Losi Strike tires rule at my local carpet track.
Zamboni is offline
Old 10-21-2011, 11:57 AM
  #22997
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by tntpower
I have
-bce chassis
-alumium hinge pin holder
-lightened outdrive
-snr graphite, shock tower,top plate,ackerman,center diff plate.
-rear t-bone bumper
-RX8
-Novak 4.5T ( waiting for my pro4 4600)
-nanotech 6000 batteries
I'm happy with my truck but i'm surprised of the final weight.
You will save weight going to the tekin. I also have an rx8 but went with the lrp for less weight.
Not saying lighter is better for everyone on every track. Just want to see how light I can make it.
One of our local sponsored guys bought one a couple of weeks ago and bone stock with pro4 4000 he whooped everyone's azz. Truck works great stock weight.
rcgod is offline
Old 10-21-2011, 11:58 AM
  #22998
porkchop's Avatar
got my bce plate today took me a week
thanks bill cant wait to mount it up
porkchop is offline
Old 10-21-2011, 12:13 PM
  #22999
slash24's Avatar
So i took my truck apart this week to clean out my diffs and put fluid in them. after i put my truck back together i noticed a squeek in the rear of the truck when I jounce the truck. has anybody else had any problems with this? it is not a performance problem, just one of those things you know is there and want fixed. can anybody help?
slash24 is offline
Old 10-21-2011, 12:24 PM
  #23000
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Originally Posted by Mr.juarez
ridley used to make them as well as chris a. they are really neat/lightweight so cool that i bought 3 sets
http://www.rcshortcourse.com/forum/p...d=1415%3C/a%3E
good luck finding a set now
DAMN! Those look SWEET!
thecman26 is offline
  #23001
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
rear springs hitting the shock body? dirt in the hinges?
Mr.juarez is offline
Old 10-21-2011, 12:25 PM
  #23002
thecman26's Avatar
I would run it, if its just a squeek, it shouldn't effect performane...
If everything feels free that is...
Old 10-21-2011, 12:50 PM
  #23003
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Ream the holes in your a arms .
BDRMBULLY is offline
Old 10-21-2011, 12:55 PM
  #23004
thecman26's Avatar
+1
Even new arms are pretty tight...
Old 10-21-2011, 02:01 PM
  #23005
Divey's Avatar
Trader Rating: 119 (100%+)
I drilled my arms out and now they move freely. They were binding so bad my rear suspension would not come back up. Also check your sway bar ball ends. Mine were new and also were binding. Now with 25wt oil the rear is silky smooth.
Divey is offline
Old 10-21-2011, 02:55 PM
  #23006
Trader Rating: 99 (99%+)
I just ordered the Chris A. stuff for my diffs, question is can I get the gasket and o rings separately or do I need to purchase the LOSB3568 package?
isarctard is offline
Old 10-21-2011, 03:37 PM
  #23007
Mr.juarez's Avatar
i always i reused the gaskets and o ring, i do have a rebuilt losi kit but i never used them in the 50+ packs i put on my losi. that is unless they arent damaged. just lightly sand the diff cup where the gasket sits and re use yours.
  #23008
Cement head's Avatar
Originally Posted by thecman26
I got my SCTE Wednesday and just got finished going through it and cleaning everything (got it used off here), would be nice to get a used car actually clean off here... But I digest... I put on the TLR Tuning kit and the aluminum shock collars wouldn't even come close to threading onto the shock bodies... I tried everything I could thing of, oil on the threads of the shocks and the collars... No dice... Went back to the plastic ones... Lil bummed...
After $130 for a hop-up kit...
But it is a very nicely laid out truck from what I have seen...
We'll see once I get it on the track!
I have the same problem, I did get the rears on, but the fronts forget it. I did have to remove the rubber o-rings to get them on and they where still a biotch! I noticed some rough threads when you look at it closely.
Cement head is offline
Old 10-21-2011, 03:39 PM
  #23009
Mr.juarez's Avatar
rough threads in the tlr metal shock cap or the shock body?
Old 10-21-2011, 03:42 PM
  #23010
TLR spring collars. Just a bit at the very start of the threads, almost like some left over flashing or flakes. That came off with exacto knife. I didn't help. Still don't have front ones on.
