Like Tree9Likes
Old 10-03-2011, 09:13 PM
  #21466
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Kylesfv
Ordered my TLR tuning kit on sunday from amain. But just making sure, do the shock caps come pre-drilled for emulsion ?
Yes just cut out your bladders.
suby723 is offline
Old 10-03-2011, 09:26 PM
  #21467
Kylesfv's Avatar
sweet thanks
Kylesfv is offline
Old 10-04-2011, 02:45 AM
  #21468
vasidudu's Avatar
Thumbs up
@ChrisAttebery,
Thx for the package, well received in Geneva today.
Still waiting :-( on my LiPo (3*6000mah 2S 65C) and my CC MMP SC with 1415/2400Kv.
All the best,
V
vasidudu is offline
Old 10-04-2011, 03:04 AM
  #21469
vasidudu's Avatar
Originally Posted by vasidudu
@ChrisAttebery,
All the best,
V
In the meantime, a pic of my ride:
https://picasaweb.google.com/lh/phot...eat=directlink
V
vasidudu is offline
Old 10-04-2011, 04:32 AM
  #21470
gtsakiris's Avatar
with the losi tuning kit for the scte how are most guys setting the F/R adjustable hinge pins for race conditions? thanks in advance.
gtsakiris is offline
Old 10-04-2011, 05:12 AM
  #21471
Wheelman82's Avatar
Default lipo
Im new to the electric sct after reading some posts im going with the Rx8 & Pro 4 4600kv motor what is a good lipo & charger set up for sct racing? thanks
Wheelman82 is offline
Old 10-04-2011, 05:20 AM
  #21472
ChefDementia's Avatar
Trader Rating: 19 (100%+)
0's all around.
ChefDementia is offline
Old 10-04-2011, 05:33 AM
  #21473
alvinsmith75's Avatar
Trader Rating: 38 (100%+)
My personal recommendation would be a Hyperion Duo charger(or any of the hyperion chargers) and a 6000mah lipo or better. I would say this would be best case scenario.
I use a Hyperion Duo 2 charger and Gensace 5000mah 50c lipos with the 4600 and mmp and I can run 8minute mains with no problem. Definately could not make 10 minutes however.
alvinsmith75 is offline
Old 10-04-2011, 06:41 AM
  #21474
Wheelman82's Avatar
Thanks for the info
Old 10-04-2011, 07:44 AM
  #21475
R6cj69's Avatar
Trader Rating: 20 (100%+)
I need some gear help folks..
I've been running my Losi SCTE for a few runs now and just like most of you i have had gear problems in the diffs.
I have replaced the stock pins with the the ones from Chris Atterberry but all my gears and shims are stock Losi. Now I did read the front page for other gear suggestions...
Other Diff gear alternatives
OFN21003 - gears and pins (only using the small bevel gears and pins..)
KYO96775 - Kyosho bevel gear washer/shims or any 4x10x.15 washers
You will need two of those behind each bevel gear to help things mesh properly. At least that's what mine needed.
Pull the losi or AE pins out and toss em on the side.. Same with the Losi gears, tiny washers and aluminum bushings and replace with OFNA gears, Kyosho washers (or equivalent).
But I still have a couple of questions...
First it says to only use the small Ofna bevel gears and pins..
Secondly the OP suggested putting two shims behind each bevel gear for proper mesh.
My questions are this.
What gear do I need to use for the larger crown gears and is everybody else using two shims as well?
I'm tired of replacing crappy gears with more crappy gears...
help please!
R6cj69 is offline
Old 10-04-2011, 07:52 AM
  #21476
larlev's Avatar
help please!
Look at getting the "Chris kit", it replaces the shims, blocks. I have 6mths of hard running on my truck and have not had a single gear issue. Pins were replaced with Chrispins at the start. I guess I've been lucky
Take a pic of your issues...would like to see damage if possible
larlev is offline
  #21477
Trader Rating: 76 (100%+)
Lipos I highly recommend thunderpower 2 year warranty. But thats just what I like.
For chargers you can spend $500 or $50 I dont know you budget
But high end are Thunderpower 810 chargers/ protek 1000 powersupplies
Low end Thunder AC6 nice balancing charger but slower
Chase1472 is offline
Old 10-04-2011, 08:23 AM
  #21478
Integra's Avatar
Originally Posted by SupermaxxRich
My truck weighs 5 pounds 14 ounces ready to race
Pics and Details Please Rich I haven't gone Full out, And the B*e chassis test the other day went Horrible So i dont know exactly the route im taking just so yet. Im sitting @ 6lbs 3-4 oz
Yes the charger is expensive but you'll save a few bucks on the packs to balance things out.
Charger
http://www.amainhobbies.com/product_...er-7S-20A-500W
Packs
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Integra is offline
Old 10-04-2011, 08:28 AM
  #21479
R6cj69's Avatar
I'll try to get a picture if I still have the gears. My last problem was in the rear diff. I believe most of the problem was due to a lack of oil. After it started clicking I took it apartand it was only about 1/3 to 1/2 filled with oil and the small bevel gears were worn pretty badly. The crown gears, shims, blocks and pins were all fine.
R6cj69 is offline
Old 10-04-2011, 08:51 AM
  #21480
Casper's Avatar
Trader Rating: 34 (100%+)
Yes the caps will be drilled in the TLR kit
0's all around in the front. For the rears we are running 1's up in the front and 0's in the rear.
Casper is offline
