Hello...I'm currently working on my TEN-SCTE. Just wanted to ask if anyone knows what setting Dustin Evans use for his front aluminum pivot supports? I'm doing an exact set-up as listed on Losi.com but cannot find any set-up sheet that has the settings for this particular part.
Thanks!
Thanks!
You talking about the slop in the steering? New ends and balls will help some but there is just a lot going on and slop will develop due to all the ball joints.
Friday nite race report...Ten min mains and finally got the fast guy with the ae 4x4 This is a truck I picked up used and am running as my outdoor truck.1st qual,truck ran good,2nd qual the steering was all over the place and I had turned up my EPA a bit from where I had it so it was a complete nightmare!Before the mains I looked at the lock nut on the servo saver and yup it was backed all the way downSo I dropped the steering speed and pulled down my th EPA to 90%.It was a real work out to get the truck to stay at the front but managed to pull off 2nd place Behind Flyin Bryan Sullivan.Who was just toying with us,pass us stop and wait then pass us all again!!Just an amazing driver and he was running an BCE chassis on his SCTE truck and was stuck to the track!!!So remember to red locktite that thing up and tite if your having steering issues with your truck!! Cheers!!
Thanks!
Thanks!
if the track is smooth I run it 1 step more upright (less caster)
better on smooth tracks
but there is a trade off
more caster= less steering
less caster= more steering
Anybody want to donate a SCTE., motor, esc...ect; to charity?? For a raffle @ the Region 5 ROAR Championship? I know it's a long shot but never know unless you try. If intersted PM me and I can send charity and race info.
Call Losi/Horizon. Our local track (G's) got one for our ROAR 2 race for our race raffle.
For those guys who've been running the SNR graphite chassis, are you guys driving them on huge 1/8th scale outdoor tracks? I've been contemplating getting one but I'm worried that it'll snap in half. I run on a huge track with 6 foot jumps. It's either the SNR or the BCE. I need to lighten my truck up especially for the big jumps. Thanks.
Lighter than the BCE, most def.
If your looking for a long lasting investment consider the BCE, the CF will look like you were driving on a belt sander in a matter of a few races.
T7 is waaay harder than epxoy resin.
When you guys are setting your ride height do you pick the whole truck up and drop it about 6 inches or do you pick up one end at a time and set one end at a time? I ask because I tried it both ways and came up with 2 different heights.
Drop the truck from a few inches and it'll be at normal ride height, go from there.
If this is the case, its likely something is binding a little somewhere. But typically, its the 6-10 inch type of drop.
Use rod ends from a different kit or brand. I'm currently using Traxxas Revo and Jato rod ends. They're not perfect though and I'm still looking for other alternatives.
The Losi plastic is cheap and deforms quite easily. You might have to end up using a different set of screws though. I think some guys here are using rod ends from the Losi 8.
Hey guys, my dad and I are picking up one of these today. I just wanted to know if there's anything I should know about servicing the car? The car is for my dad, but I'll be doing any repairs or regular maintenance. How often should I service the gear diffs? Are there certain components that need regular tightening? I just need a little help so I can keep his car in tip top shape.
Thanks!
Thanks!
after setting up shocks dropping it, setting up ride height, I noticed the rear end seams to stick and not rebound as fast as the front, running silver springs back, gold front, 40 front 25 rear oils. checked for binding it all good, with out shocks. is it sticking on landing like a cat, is this good or should I free it up some ? bu moving the shock locations ? Thanks
I suppose I'll go with a milled aftermarket chassis. Now I gotta figure out whether to get the Losi, BCE, or Bump. I wish someone had a comprehensive comparison of the 3.
