..WOW
Stock shock oil f/r - 30w from the factory. Stock Diff's come filled with grease. When disassembling the diff housings, be careful when removing the screws. They have been known to be in tight and require a 1/16th sized hex.
Stock spring rates
Black springs front/rears
The current fronts are 3.6, 3.9, 4.3
The current rears are 3.0, 3.3, 3.6
Spring rates for LOSB 2959 Front set
Green - 3.6
Blue - 3.9
Black - 4.2
Purple - 4.5
Spring rates for LOSB 2963 Rear set
Red - 2.7
Orange - 3.0
Silver - 3.3
Green - 3.6
Losi Updated Spring Sets
http://www.losi.com/Search/Default.a...m=ten%20spring
Shock Piston sizes:
#1 0.95mm | #2 1.00mm |#3 1.05mm | #4 1.10mm | #5 1.15mm
Diff housing screw size (for people who have stripped the screws and want another option) Four screws - 2.5mm 45 pitch 10mm. HPI has some screws that work part# Z449 , they are M2.5x12mm 2mm longer than stock but the holes are deep enough in the diff housings.
Diff fluid starting points.
Indoor blue groove 5-7-3 (Front/Center/Rear)
Indoor blue groove 5-5-3 (Front/Center/Rear)
Outdoor med bite 3-3-2 (Front/Center/Rear)
Stock spring rates
Green - 3.6
Blue - 3.9
Black - 4.2
Purple - 4.5
Red - 2.7
Orange - 3.0
Silver - 3.3
Green - 3.6
Shock Piston sizes:
There are so many different types of aluminum alloys (like 6061 & 7075) and different tempers (like T6 & T7) it does get confusing because the numbers cross over (like 6061-T6 & 7075-T6). I have tested several alloys on a couple different vehicles and the 7075-T6 performed and held up best overall. It didn't bend as easily and came off the track with the smoothest surface on the bottom. The 6061 handled well, but it bent easy and the bottom got chewed up and looking like the stucco on the side of my house. When you watch these heavy trucks in slow motion video, they bottom out and slide up the face of the jumps. When the bottom surface of your truck is rough, it's like hitting the brakes and the truck does not fly as far. I also hard anodize the chassis to keep the surface from getting chewed up and lasting longer.
I ran a big race this weekend and lost my front drive shafts twice in one day. the pin fell out so I bought a new one and put it in and in the main it came out again. Is there a diffrent brand or a fix for this issue
No disrespect intended but no one could pay me enough to visit any of those sh*t hole 3rd world countrys.
Hope your happy with yourself about being so defensive and on-board with taking potental jobs away from Americans ?
A lot of your statements and retorts remind me so much of Jason from MaxAmps ?
Hell, Toyota and Nissan are more made in America than Ford and Chevy.
When the politicians start making decisions that truly help American businesses instead of decisions based on re-election the "old" days may come back.
To flame Ryan over something that has nothing to do with him is absurd...you and cwilkinson both are getting attitude at the wrong guy.
Wow all I can say is wowzzzer!!
I will be buying all 3 aftermarket chassis. I dont see why people cry about where the item is from. Either your racist or just want something to cry about. Do us a favor and shut up.
I support made in America. That's why I drive a Tundra , built here in San Antonio. Someone who can't even correctly spell the plural form of "country" is probably not worth arguing with.
