TLR 22 Racing Buggy Thread >
Like Tree1Likes
Old 02-22-2012, 12:32 PM
  #14131
Originally Posted by Ruffy
I'll check tonight but I am nearly certain mine did not rub on the motor plate as it free-wheeled easily with no grinding noise (motor pinion off), and I did try it with the AE V2 spring and spacer. Still did not notice any performance improvement at all, but did notice the Losi Spur was a little quieter.
I'll check just to make sure when I get home, but after trying them all out, I prefer the stock Losi Slipper.
Right on, and it could be just how mine was. It was rubbing, but it only needed about .5mm for clearance.
My main reason for running it is because I could not get the stock one set where I needed it. Bench setting the slipper was impossible, I could tighten the nut all the way down and when hitting the throttle the front end would barely twitch.
Sean B. is offline
Old 02-22-2012, 12:36 PM
  #14132
Ruffy's Avatar
I hear ya Sean, that's the problem I had with the AE slipper which is confusing.
If you or anyone is home, could someone post what the OD (outside diameter) of the V2 plate where the spring rests is? Id like to know to find some washers here at work that I can use there as spacers to increase spring tension, to try the V2 spring again with the AE plates as I bottomed it out on the shaft last time and it slipped easily.
I should have measuered this at home, but since I wasn't planning on trying it again until just now...
Ruffy is offline
Old 02-22-2012, 12:41 PM
  #14133
e_lu_sive1's Avatar
wow since 84 ruff? i was like 10..
e_lu_sive1 is offline
Old 02-22-2012, 12:45 PM
  #14134
Ruffy's Avatar
I was 21 back then!
Ruffy is offline
Old 02-22-2012, 12:53 PM
  #14135
e_lu_sive1's Avatar
wow! thats awesome! u still representing!
Old 02-22-2012, 12:56 PM
  #14136
Originally Posted by MrGidi123
Best buggy on carpet!
I couldn't agree more.
Ivegotklas is offline
Old 02-22-2012, 01:05 PM
  #14137
I got 10.3mm.
That is really strange, as I'm no where near bottoming the nut out now.
No shims or anything, just the v2 spring and plates.
I am using a Jconcepts machined gear, not sure if that would make a difference
Sean B. is offline
Old 02-22-2012, 01:06 PM
  #14138
Ruffy's Avatar
Thank-you!
Ruffy is offline
Old 02-22-2012, 01:13 PM
  #14139
HighLife420's Avatar
Trader Rating: 49 (100%+)
I was 8 and racing...well back then, it wasnt really racing like it is now. People raced Grasshoppers and Hornets. Even had a friend who raced a Wild Willy.
HighLife420 is offline
Old 02-22-2012, 01:19 PM
  #14140
Ruffy's Avatar
I raced only RC10's for many many years.
10.3 mm (.405") seems big, so that is roughly the ID of the spring?
Ruffy is offline
Old 02-22-2012, 01:20 PM
  #14141
e_lu_sive1's Avatar
i had a hornet..remember the mugen manx?? My pops had that.
Old 02-22-2012, 02:00 PM
  #14142
chaseman1's Avatar
I raced a xx-t and a xx at MnM hobbies in Corona, Ca. I was pretty young then I think 6th or 7th grade
chaseman1 is offline
Old 02-22-2012, 02:02 PM
  #14143
Dougoilman661's Avatar
Do you guys prefer the TLR nut type hingepins or the e-clips ones? How likly are the eclips to pop off in a race?
Dougoilman661 is offline
Old 02-22-2012, 02:10 PM
  #14144
e_lu_sive1's Avatar
the captured ones are easier to tune for me..e clips are cool if u stay away from hits..
Old 02-22-2012, 02:11 PM
  #14145
Casper's Avatar
Trader Rating: 34 (100%+)
I am not sure I have ever lost a rear outer hinge pin e-clip. They are protected pretty well inside the wheel. With that being said though I like the nut version!
Casper is offline
