Like Tree1Likes
B44.1 Thread
Old 07-21-2012 | 01:56 PM
  #2491
How do you set your slipper? I had a 81 spur in there but changed to 84 because I thought that would bring the temps down and right now my slipper is tightened all the way.
The8ight is offline
Old 07-21-2012 | 02:02 PM
  #2492
fastchvy's Avatar
stick a allen in the blue slipper nutt and roll your car forward or backwards tilll you feel your slipper loosen up..then from a dead stop punch it and it should slip a little right off the bat...what esc and motor your running...are you running a fan on the esc?
fastchvy is offline
Old 07-21-2012 | 02:06 PM
  #2493
Lrp tc spec and lrp x12 6.5 and yes I have a fan
The8ight is offline
Old 07-21-2012 | 02:14 PM
  #2494
fastchvy's Avatar
i ran the exact same set up...loosen the slipper an run 18/81 and you will be good.......do you have timing in the motor end bell or in the esc?
fastchvy is offline
Old 07-21-2012 | 02:15 PM
  #2495
Okay will do, thanks.
The8ight is offline
Old 07-21-2012 | 02:19 PM
  #2496
Can I just keep the gearing I have now 17/84 and loosen the slipper?
The8ight is offline
Old 07-21-2012 | 02:26 PM
  #2497
fastchvy's Avatar
its alot of gear, thats 80 percent of the problem
fastchvy is offline
Old 07-24-2012 | 08:22 PM
  #2498
What is the reason for running that gearing? Seems a little off. The slipper is designed to save your diff, not compensate for the wrong gearing. Tightening down your slipper all the way and running 17/84, id be curious to see what temps you are running. Did someone bring the marshmellows?
zipperfoot is offline
Old 07-24-2012 | 08:28 PM
  #2499
Read the manual. Tighten it so the shaft sticks out 10mm. I find that to be an almost perfect starting point.
Old 07-24-2012 | 08:36 PM
  #2500
rigor's Avatar
Yeah you don't want your slipper tightened *all* the way down; then it won't slip at all, and defeats the whole purpose. Like the above user said, right around 10mm as the manual states is a good place to start. When set right, you should hear the slipper make a high pitched slip/squeal sound for a few feet (like 1 yard) after hard take off from a stand still.
rigor is offline
Old 07-24-2012 | 08:39 PM
  #2501
I change the gearing 17/81 and drove it with my slipper loose a bit then something in the rear diff messed up and my car wouldn't move anywhere. So I gotta check that out maybe the diff balls busted. I lossene it just a bit and it slipped really hard, so tightened backed upa bit and then the diff busted. So I ordered some
Balls and are waiting on them now
The8ight is offline
Old 07-24-2012 | 08:51 PM
  #2502
Matt Trimmings's Avatar
If anybody is looking for a sweet deal on a barely ran FT B44.1 just let me know...
Matt Trimmings is offline
Old 07-25-2012 | 06:04 AM
  #2503
Just replacing the balls is not going to fix the problem. Sounds like you fried your diff with the slipper cranked down. You are going to need the thrust and diff washers., diff and thrust balls, and you say the diff busted? Sounds like the shaft or the nut will need replacing as well.
Old 07-25-2012 | 08:31 AM
  #2504
Well haven't checked the rear diff yet but I have check tw front and it wasn't the front sO I'm pretty sure it's rear, I just haven't had time I will try tO check it out tonight
The8ight is offline
Old 07-25-2012 | 03:07 PM
  #2505
bergie33's Avatar
Those of you using Losi BB shocks, what springs are you running? I run on an indoor medium/high bite indoor wet clay track. It seems like running just the BB springs most are going with red/white or red/yellow. Would the same hold true with the Losi shocks in there too?
bergie33 is offline
