Like Tree1Likes
B44.1 Thread
Old 03-27-2012 | 04:04 PM
  #1741
Originally Posted by TheHillsPancake
any tips on building the diffs ??
I just followed the manual. I did nothing special other than run a surface grinder over the diff rings to make sure they are flat. The gears felt a little tight but I'm sure they will break in fast.
nhraman is offline
Old 03-27-2012 | 04:26 PM
  #1742
to make the car a little quiter you can put a couple drops of 50wt shock oil on the diff gears front and back.
JoshCorti11 is offline
Old 03-27-2012 | 04:37 PM
  #1743
Yes, I did that.
nhraman is offline
Old 03-27-2012 | 04:39 PM
  #1744
i put like 2 drops of diff lube or does 50wt shock oil work better ?
TheHillsPancake is offline
Old 03-27-2012 | 05:03 PM
  #1745
fastchvy's Avatar
Are you running the balast weight?
Do you know how to set the diff and slipper?
What motor are you running?
fastchvy is offline
Old 03-27-2012 | 05:14 PM
  #1746
I would say go with the 50 wt shock oil it is thinner and will not make the gears stick at all, it will also keep your tranny nice and free
Old 03-27-2012 | 05:26 PM
  #1747
i am not running the balast weight yet.. and and i am new to 4wd diff set ups so i am going by the manual, if you have a better way of doing it please tell.. and im gunna put the tekin rs pro with a 6.5 in it.. gunna be racing at WCRC if that helps
Old 03-27-2012 | 05:29 PM
  #1748
fastchvy's Avatar
Heck ya....hit me up, i will help you get it rockin...i run the all orange 44.1...just layed down a 14/5:06 saturday night witch is pretty quick...my car feels sick!...i will pm you my number..
fastchvy is offline
Old 03-27-2012 | 05:34 PM
  #1749
Suspended
Hey guys I just picked up a b44.1 and was wondering what shock oils with the stock springs would be a good all around setup?
MattP is offline
Old 03-27-2012 | 05:37 PM
  #1750
fastchvy's Avatar
Front
Silver springs
#2 piston
Ae 35 wt oil
Rear
Green springs
#1 piston
30wt ae oil
fastchvy is offline
Old 03-27-2012 | 06:09 PM
  #1751
alrite will do man.. thanks for the help cant wait to drive this thing..waiting for my front shock tower to get in cause my kit didnt come with one
Old 03-27-2012 | 06:38 PM
  #1752
fastchvy's Avatar
I will be at wcrc tomorrow if you can make it down to break it in...
fastchvy is offline
Old 03-27-2012 | 06:46 PM
  #1753
Mini8 Menace's Avatar
Default hey do you use the t-nut spacer
hey i am done with my kit and i just noticed i have t-nut washers to the diffs they look like they would go on the opposite side of the diffs from the t-nut and they were connected to the t-nut in the kit but it says nothing about them???do i use them????
Mini8 Menace is offline
Old 03-27-2012 | 06:48 PM
  #1754
Originally Posted by nhraman
Yes, I did that.
Old 03-27-2012 | 07:13 PM
  #1755
i would go down there if i had my front shock tower and my motor and esc but there still on there way
