Like Tree1Likes
B44.1 Thread
Old 04-11-2012 | 02:06 AM
  #1891
D3mOnIcRc8e's Avatar
Do you guys have the part number for the chasy guard ?? you know the seethru thing that protects the bottom.
D3mOnIcRc8e is offline
Old 04-11-2012 | 02:25 AM
  #1892
Lofreq's Avatar
Part #: 9773
thats the undertray from AE..
Lofreq is offline
Old 04-11-2012 | 02:28 AM
  #1893
Thank You. So do most people run the under trey or the stick on sheet ?? Does the under trey also stick on or bolt on ??
  #1894
Lofreq's Avatar
Originally Posted by fastchvy
A little feedback....
what is this c-hub or c brace i see people talking about?
http://teamassociated.com/parts/details/9873/
Lowers the outer link for lower roll center.
Lofreq is offline
Old 04-11-2012 | 02:32 AM
  #1895
Lofreq's Avatar
I run it on a dusty outdoor track. other than that i usally dont. It uses chasis screws already there. It tucks under front bumper and rear bumper also.
On a cool factor it can be painted to match your body tho. Ive seen people use the thick stick on protector also.
In my opinion its all up to the user.
Lofreq is offline
Old 04-11-2012 | 03:03 AM
  #1896
That's even confusing me more...
Most drivers are running BB KYO yellow front. But if i follow the sheets on petitrc(they measured the Kyosho spings), the yellows(3.60 measured)should be way softer then the silver AE.
And for the rear, most are running KYO white, but they are measured 2.10 and quite a bit harder then the AE green ones.
So, should the car not be out of balance, if the most common setup seemed to be AE silver front/ AE green rear????
ron63 is offline
Old 04-11-2012 | 05:33 AM
  #1897
Has anyone used these batteries ???/ They seem to be good for the price.
http://www.hobbyking.com/hobbyking/s...dProduct=17270
Would they work ??
Old 04-11-2012 | 09:14 AM
  #1898
TJMac's Avatar
Would they work ??
I haven't used them but they should fit (looks like a standard saddle pack).
TJMac is offline
Old 04-11-2012 | 09:20 AM
  #1899
idrummerboy13's Avatar
Would they work ??
i have these and they work fine, pretty good punch but they work.
idrummerboy13 is offline
Old 04-11-2012 | 10:23 AM
  #1900
fastchvy's Avatar
Originally Posted by forcewave
I've had nothing but issues since I finally recieved my batteries. First I have to extend the damn posts to make the batteries fit then I have to make space so the jumper cable between the two packs fits. I've still got suspension binding in the front end while turning. To top it all off I used blue loctite per their recommendation and I have broken 2 tools off trying to remove screws. Now I'm having to drill out screws I don't even have replacements for. I've put lord knows how many hours into it and still can't run the damn thing. So I've got a 1200 dollar paper weight sitting on my workbench. You can't even begin to imagine how pissed off I am, I baught what was considered the best for a reason. I can't sell the damn thing because I'd just lose money, and yet now I don't even want to work on it.
Use the sticker sheet
fastchvy is offline
Old 04-11-2012 | 09:47 PM
  #1901
So im stuck on what batteries to get, i was thinking on the turnigy nano tech ones but then i was told gens ace batt. are better but i cant find a higher C rating than 25 on the gens ace. im looking for for like a 40c and atleast 4800mah. what do you guys think ??
Old 04-11-2012 | 10:07 PM
  #1902
Lofreq's Avatar
the turnigy ones will work real nice for ya. Few guys locally run them with no prob. I even have a couple for my boys truck. They run them hard and have nver had a prob with them.
Lofreq is offline
Old 04-11-2012 | 10:08 PM
  #1903
fastchvy's Avatar
Honestly i run the turnigy nano 6000mah in my son losi xxx sct and the are great, he also has 2 reedy 5500mah packs and there is no difference, infact i think the nano tech has more punch...i got the 2 nano tech batteries plus the shipping to my house for 120.00....reedy pack alone was around 100.00...and if you pick 3 day shipping, i gets here in 3 days, i was shocked...im going to get a few sets for my new 44.1
fastchvy is offline
Old 04-11-2012 | 10:50 PM
  #1904
So im runnign a mamba max pro with a novak 6.5 what c rating should i go with ??? i was thinking the 50c tp 100c or the 65c to 135c ??
Old 04-11-2012 | 10:56 PM
  #1905
fastchvy's Avatar
i would go with the higher rating
fastchvy is offline
