Like Tree1Likes
B44.1 Thread
Old 07-01-2011 | 04:48 PM
  #391
Buckaroo's Avatar
Any major advantage to the B44.1 (~$370 new) over the B44 (~$220 new)?
Buckaroo is offline
Old 07-01-2011 | 06:50 PM
  #392
Small changes only... mostly to make it easier to work on, not so much for performance improvements.
Banshee8530 is offline
Old 07-02-2011 | 10:41 AM
  #393
Quick question: do the Trakpower 4800 saddles fit in the FT saddle pack tray? Thanks!
adam lancia is offline
Old 07-04-2011 | 03:18 PM
  #394
Anybody?
Old 07-04-2011 | 04:33 PM
  #395
racer_guy's Avatar
jw...does the kit come with the ca glue and threadlock? manual suggests the use of them in a few spots. pickin mine up soon just want to be prepared. thanks
racer_guy is offline
Old 07-04-2011 | 05:28 PM
  #396
No and no.
goin2drt is offline
Old 07-04-2011 | 06:36 PM
  #397
I don't personally use those batteries but based on the manufacturer's given dimensions they will fit. They are 30mm high, so you might have to set up the jump cable so the it leaves the bullets at a 90-degree angle, other than that should be fine.
Old 07-05-2011 | 12:05 AM
  #398
Great, thanks!
Old 07-11-2011 | 03:33 PM
  #399
big chris's Avatar
Bought one today. Guess I will be reading through these pages for some info.
big chris is offline
Old 07-11-2011 | 07:30 PM
  #400
Congrats you will love it.
goin2drt is offline
Old 07-11-2011 | 07:34 PM
  #401
Default Need help
So check this out. This is weird and not sure if anyone has suggestions. So I am running my car all day on Sunday. Car is awesome and set up is perfect. In the first qualifier I break my right front a-arm. No big deal I replace it for the next race.
For whatever reason after replacing the a-arm now all of a sudden my car is horrible. It is really lose in the rear all over the track. Almost so bad it was really hard to even drive, it drove like my 2wd. It was fine going straight but on and off power in turns it just kept spinning out.
I know it is a long shot but any thoughts before I just tear the whole thing apart and check everything?
goin2drt is offline
Old 07-11-2011 | 09:07 PM
  #402
Tron's Avatar
Broken driveshaft pin or damaged outdrive?
Tron is offline
Old 07-11-2011 | 09:52 PM
  #403
Cool
Mine arrived in the mail today too! Can't wait to get started on building. Still no idea what motor/esc I'll be getting though??
Flipu is offline
Old 07-11-2011 | 10:10 PM
  #404
So, what are the hot saddle batteries these days? I'm having a hard time locating many options, especially for ones that come with built-in wires and a Dean's connector. I wish I could get some with at least the same specs as the 5300mAh/65c Thunder Power battery that I run in my other car... The best I've seen are 5200mAh/60c Losi and Reedy packs.
EricJ is offline
Old 07-12-2011 | 12:47 AM
  #405
big chris's Avatar
Anyone here have a 1410 3800 Castle in their B44.1? I have a Mamba Max Pro esc and 3800 4 pole motor in my 4x4 I may put in here to see how it goes.
Any opinions, gearing info? Thanks
