B44.1 Thread
#362
interim report out ... completed the build .... opted to simply dremel out an indent in the rear top plate to accomodate the regular bullets since I couldn't wait for the low profile ProTeks to show up ... I'll buy a new rear top plate if this one breaks ;-)
Anyway ran the B44.1 on the baseball diamond - mistake ... totally crudded up the interior with sand and gravel ... luckily had an air duster in the car ... somehow dropped the front right CVA when running on grass ... looking for advice on how to setup so this happens less if at all
dumb move - ran on the local street ... hitting somewhere north of 45mph *easily* ... can hear the slipper slipping on start up so I'll tighten that up soon ... anyway, crashed fairly quickly, broke a front A-Arm ... now I've been waiting for a regular replacement for about a week ... has anyone played with the GPM aluminum hop ups?
#363
Front arms breaking is just a fact of life with the 44. Just buy a few packs of front arms, shock shafts/ends and some shock caps and you should be covered. Aluminum arms will just bend or break other parts of the car that are harder to replace.
#364
I just finished my build and my front CVAs are right on the cusp of popping out at full droop. I like to drive on throttle, so I will likely add a limiter or two to the front shocks, but I have to see how it works as it sits.
#365
Does anybody run an LRP SXX v2 or v1, NON TC spec in their 4wheel without any problems? Seems like everyone runs the TC spec.. Im about to pick up a B44.1 and have a brand new SXX that I could use if its enough speedo.
#367
#369
I have almost got it all by just asking them each time I am there and making a few adjustments here and there.
#370
Tekin 7.5 geared 24/81 with 12* of timing on the can. About 140 on the motor and 140 on the speedo after 7 minutes. SXX version 2 with the recommended settings of 3434.
I think I'll get rid of the boost and see what that does for temps. 7.5 is more than enough motor as is. I also have a small fan that I can mount to the chassis if all else fails. One of the locals runs around 180* weekly. He's running an SXX V2 as well.
#371
#375
Good luck. I have been trying forever to get a set up sheet for WCRC (hard pack clay) which they have as most of the AE guys race there all the time. Even emailed them and nothing posted.
I don't get a chance to run a lot of indoor in my neck of the woods but speaking with some of the guys closer to indoor tracks, they start with similar concepts
1Likes
