B44.1 Thread
#241
Hey guys, I just bought a new B44 and built it 100% accurate to the manual. I took it to the track and popped the rear drive shafts out 2 times in 5 minutes of driving. I double checked the shims the on the hub, and pulled the shocks apart to check if I forgot the limiter. everything checks out. What else can I do?
#242
#244
should be okay... hotter motors need lower gearing and an 8.5 will run a 22/81 pretty easy. 23/81 is 8.83:1 final drive ratio, this should be reasonable for a short track. Be sure to monitor ESC and motor Temp during practice.
#247
Anyone have a good picture of Ryan's car without the body on? or Cavaleri's? I want to see if they have weights anywhere somethingn special the factory team kit doesn't have.
#248
#249
From: Conducting aggressive board meetings at my local track
#251
I just ordered a kit and expect it later this week. I have yet to pick out a brushless system for it. I'm 100% new to 10th scale 4wd, but have ran a little of everything in the past. I'm gonna be racing this on an outdoor track thats a little tight. I was thinking on a 7.5 or 8.5, but unsure on brand. I didnt want to get the ultilmate-best, but something descent and mainly dependable. I'm also un sure on a steering servo, and dont want to spend a lot on one. Maybe a trusty hitec 625?
So if you were in my shoes, what would you power this thing with?
#253
#254
#255
Guest
I am pretty sure I see a part of "JConcepts" text on those tires.
1Likes
