Like Tree1Likes
B44.1 Thread
Old 04-11-2012 | 11:36 PM
  #1906
D3mOnIcRc8e's Avatar
Ok Cool thanks for all the info guys.
D3mOnIcRc8e is offline
Old 04-15-2012 | 01:58 AM
  #1907
My nephew would like to run with his friends on a paved track with his b44.1,as ill be buying him a set could someone please recommend a tyre.Maybe pre mounted?He has the 12mm hex adapters.
Cheers Mat.
MatRE is offline
Old 04-15-2012 | 05:32 AM
  #1908
tibbs's Avatar
Can someone help me with the shimming on the diff.. I have had my b44.1 for two weeks now and have gone through two main gears on the rear diff .. I had a fs2 and never had a diff problem like this before its getting very frustrating. Can someone give me some pointers to help me with this diff problem.......
tibbs is offline
Old 04-15-2012 | 08:11 AM
  #1909
SAMCRO's Avatar
I have a BJ4 worlds edition car that has been collecting dust for the past few years. I would like to upgrade it to the B44.1 A lot of things look the same (shocks, diff, ect..). What are the exact differences? Could I simply buy the b44.1 chassis, arms and shocks towers and swap them out with the BJ4 ones?
SAMCRO is offline
Old 04-15-2012 | 09:10 AM
  #1910
idrummerboy13's Avatar
I had the same problem, shim the diff towards the smaller pinion gear and if the pinion gear moves back and forth that could be bad also, I didn't catch that until 5 gears later, make sure that doesn't move either. Now I like to shim the transmission on the tight side so it lasts a long time.
idrummerboy13 is offline
Old 04-15-2012 | 01:48 PM
  #1911
Anybody run the lrp x20 yet?? Hows it compare to the reedy sonic or triniy duo 3???
rickybobbyxxx is offline
Old 04-16-2012 | 01:14 PM
  #1912
Tyler Keel's Avatar
6 on the gear side, 4 on the opposite. You want no side to side movement of the diff within the housing.
Tyler Keel is offline
Old 04-16-2012 | 03:00 PM
  #1913
SuperRC's Avatar
I have also had this same problem except that I was getting damage to both front and rear diffs. I was rebuilding diffs every week. The manual states to put 2 shims on one side and four on the other. I have added an extra two shims on each side. So far the front diff has behaved after 3-4 races. Although the rear has improved I think it still needs more shims. Unfortunately its a trial and error process, you may need to sactrifice a couple more bevel diff gears before you find your right fit.
SuperRC is offline
Old 04-16-2012 | 03:23 PM
  #1914
Yeti AS3's Avatar
I can't rember how many shims came in the kit, but I probably added 3 or 4 more over that to get it snug.
Yeti AS3 is offline
Old 04-16-2012 | 05:22 PM
  #1915
Man you guys scared me about the diffs so I pulled mine apart. I have about 15 races on mine now and they still look like brand new!! I guess I'm the lucky one. My concern and only thing I don't like about the car so far is the steering rack. Whats up with all the play when steering all the way left or right? Something just doesn't seem right.
nhraman is offline
Old 04-16-2012 | 07:41 PM
  #1916
tibbs's Avatar
Thanks guys for all the help with the diff I put 6 on one side and 4 on the other side and it feels alot better so we will see how it works this weekend... Thanks again guys...
tibbs is offline
Old 04-17-2012 | 06:22 AM
  #1917
Tyler Keel's Avatar
Welcome to Associated sir.
Old 04-17-2012 | 06:30 AM
  #1918
Man im poretty pissed off, i ordered the neotech batteries from hobbyking and i have yet to get them or get a traking number that works. i hit up the costomer support like 3 days ago and they still have not gotten back to me. Ugh this is bull.
Old 04-17-2012 | 06:53 AM
  #1919
Just finished cutting out and painting the new body. Im still pretty new at painting bodies but im happy it matches my rc8
Old 04-17-2012 | 02:31 PM
  #1920
dekar058's Avatar
Default wheel hexes and rims
Hey can anyone tell me which wheel hexes and rims are the best setup for the b44.1? Thanks for your help in advance.
Derek
dekar058 is offline
