Like Tree1Likes
B44.1 Thread
Old 03-12-2012 | 11:00 PM
  #1591
-WHEELMAN-'s Avatar
Originally Posted by UN4RACING
I give the 44.1 a 10 on fit and finish. I have not had any trouble to speak of on my 44.1. You will get a lot different feed back that shows most issues are of a personal problem that varies from each of us. I set my servo saver tight my slipper tight and I shim the gear side of the diff with all 6 shims and 5 spots of grease on the gear. Really that's all I would recommend on a new or rebuild. Your gonna break an A-Arm shock shaft and maybe a cap. So have shock eyelets shafts and arms and caps. The kit will out perform any other in its class plain and simple. Its the best of the best in its class IMO. Run it box stock and tweak it from there. After you hit the track you may want to try some hop ups but out of the box it has every thing you need to run with the front of the pack. I have enjoyed mine so far.
Love mine can't say it any better than you did!!
-WHEELMAN- is offline
Old 03-13-2012 | 05:13 AM
  #1592
RickSlick's Avatar
Thanks all for your comments on the car.
Rick
RickSlick is offline
Old 03-13-2012 | 06:38 AM
  #1593
UN4RACING's Avatar
I have to say. Just from racing at our track I see people buy 4x4 kits and then they have to buy this and that to make it stronger or perform better and so on. Like for example the Kyosho. Everyone buys the kit at 500 or what ever it is then at the same time they buy a plate to keep it from breaking on the front chassis. Or they get the Durango and spend endless hours chasing a set up to catch a 44. There threads are a constant try this try that buy this buy that. And they all have little parts support. Any kit can run up front but not like the 44.
The 44.... Buy it build it race it. Hell our thread is hardly on the front page. Until every one started trying BB springs and BB shock bodies we had nothing to even think of trying to make it better. The reason? Nothing is required to dial it in. The box stock set up works at almost any track. Just add weight or take it away. No other kit is this adapted to racing. Tires are about all we really have to chase on set ups. No other kit is that unique. I can change an A-Arm with out pulling the front tire off. I have to hand it to the test and tune team before they release there kits at AE.
I know we all want gear diffs but then we would go back to the gear because we would realize its easier to adjust than pulling them and trying different oils and grease. And for my diffs I get months out of them anyway. Its the best platform in the class plain and simple.
Its funny when someone says I'm starting a 44 build what do I need to a make the kit good on a build. We say nothing.
Just stock shock eyelets front shafts and shock caps and a-arms and your set to travel to any track. 20 bucks worth of spare parts will last a long time.
If you really want to race 4x4 and your serious about racing you have to try the 44 its just that good of a kit.
I know I'm preaching to the quire. But someone besides a 44 racer may just read this thread.
UN4RACING is offline
Old 03-13-2012 | 06:39 AM
  #1594
UN4RACING's Avatar
oops echo post.
Old 03-13-2012 | 08:32 AM
  #1595
RCHR's Avatar
I cut the threads off a 1.02 shock shaft, and die cut larger 5-40 threads on the end for a much stronger front shock shaft setup.
RCHR is offline
Old 03-13-2012 | 09:38 AM
  #1596
-WHEELMAN-'s Avatar
Feel like making some money and making more?
Old 03-13-2012 | 06:01 PM
  #1597
idrummerboy13's Avatar
i love my b44.1, finally been able to feel this thing so much
i broke one a arm when i jumped wrong and hit the wall my fault
i do wish a.e gave more shims bc I found the mesh was tight just the pinion gear was moving, shimmed that closer to ring gear and I have used it 5 times or raceways without a strip.
Also can make use of my baldies for my 2wd=] and if a quick scuff in is needed, this is what i use
stock springs felt great but i like yellow and greens, blue front springs when i need less steer, switched down to 32.5 oil front, 27.5 rear. It reacts better and I can push it harder.
idrummerboy13 is offline
Old 03-13-2012 | 08:53 PM
  #1598
fastchvy's Avatar
I'm looking for a b44.1 chassis and a complete set of v2 shocks if anybody has anything laying around....im going to purchase new here in a few days but i wanted to see if any members had anything laying around first!!
fastchvy is offline
Old 03-13-2012 | 09:33 PM
  #1599
Yeti AS3's Avatar
Check the for sale forum, somebody had a new, un-assembled set.
Yeti AS3 is offline
Old 03-13-2012 | 10:11 PM
  #1600
fastchvy's Avatar
I tried, looked at over 1000 threads starting with the search button...i give up...still looking if anybody has anything
fastchvy is offline
Old 03-14-2012 | 05:12 AM
  #1601
Default bb springs
Hey guys
Need some help???
I run on low grip to med grip tracks & use standed ae spings, what losi bb spings would you guys use???
What is the difference between the punnisher & the finnisher??
Need new packs & i can get reedys 5200 60c or orion 5500 90c which wons are better???
I just got some ghea taper pistons,which way do you run them,taper up or down???
thanks
ghost rider is offline
Old 03-14-2012 | 05:34 AM
  #1602
UN4RACING's Avatar
Originally Posted by ghost rider
Hey guys
Need some help???
thanks
I think we will see some AE Big bores in the Cactus race coming up. Hold out and lets see what AE comes out with.
We ran with Tebo last night. And my 60c where just as good as his 90c. But I do run a 6.5. Run a high down force wing on low bite tracks. Leave the cut out on the wing full. Don't cut it out and try longer camber links. 2 degree rear camber helps and if you want to go all the way? run zero anti squat, it improves side bite. Good luck on tires its a testing night mare on dry tracks but I have great results when ours is dry running super soft rebars.
Old 03-14-2012 | 08:13 AM
  #1603
burgboyz's Avatar
After my very first ever run on dirt off road, I have to agree!! Plus the durability of this kit is outstanding!! I put it to the test last night that is for sure and I didn't break or bend a single part.
It was alot of fun last night and thanks for all the help. I learned alot about off road just watching the lines that you and Tebo were running. Now just need more wheel time! (and eventually more motor. )
burgboyz is offline
Old 03-14-2012 | 11:25 AM
  #1604
UN4RACING's Avatar
You did pretty goid for a first timer. Just quit hunching that concrete wall...lol. I I wish I had that on vid. It passed the durable test thats for sure. And nothing like getting schooled by Tebo. I love practice nights. No pressure laps.
Old 03-14-2012 | 11:38 AM
  #1605
Hey UN4racing.....
Thought I overheard you saying you were feeling pretty good about your setup, and you said, "your 4wd buggy was keeping up with TEBO's 2wd buggy" ....
Love ya
BSYDOR is offline
