Like Tree1Likes
B44.1 Thread
Old 03-15-2012 | 08:41 PM
  #1621
Yeti AS3's Avatar
Originally Posted by nhraman
I just got my B44.1 yesterday, what are you guys running for batteries? I'm just curious what C rating/MAH I should get with a 7.5 motor? Thanks for any help you can give me.
I run a Revtech 7.5 w/Nano-Tech 5100 60c. They are great batteries. I can't tell you how much runtime since I usually don't run more than 10 minutes at a time.
Yeti AS3 is offline
Old 03-15-2012 | 09:19 PM
  #1622
UN4RACING's Avatar
I really have had great results out of my Reedy 5200's. I balance them before the race once each week. 10.5 down to the 5.5. flawless packs all winter so far.
It seems I saw something a newer pack coming to?
http://www.teamassociated.com/reedy/parts/details/627/
UN4RACING is offline
Old 03-17-2012 | 08:25 PM
  #1623
Thanks guys, I ended up buying a couple Fantom 65c saddle packs. I run Fantom motors and batteries in all my other cars, so I figured I'd stick with them on this car as well.
nhraman is offline
Old 03-17-2012 | 10:36 PM
  #1624
KING_PALM's Avatar
Kyosho Big bore Oils with yellow fronts and white rears.
I was told 35F 32 1/2R with the stock 5 hole pistons.
I am running the cav setup at west coast.
was runnning 27 1/2 in the front an 25 in the rear and it was kinda bouncy.
KING_PALM is offline
Old 03-18-2012 | 01:12 AM
  #1625
This is my nephews which I put together for him.We took it for a spin today and he only run for 10min or so and he got a rock between the spur and pinion,guess what won lol.Ive ordered another spur,but seriously I cant keep doing this.Do they make a metal spur for it?Sorry couldnt post up a picture of his car which is just weird.
Cheers Mat.
MatRE is offline
Old 03-18-2012 | 02:35 AM
  #1626
MrGidi123's Avatar
LOL guys put a 6.5T motor in
MrGidi123 is offline
Old 03-18-2012 | 05:33 AM
  #1627
UN4RACING's Avatar
Cheers Mat.
Don't know of any? You should be able to hit the local hobby shop or track for any parts. Saves time from ordering by mail.
Old 03-18-2012 | 05:40 AM
  #1628
Thanks for the reply.Problem is I dont have any local tracks or lhs,bit remote lol.I order online.
MatRE is offline
Old 03-18-2012 | 05:52 AM
  #1629
UN4RACING's Avatar
Bummer. If your bashing you may want to modify some sort of gear protector.
Old 03-18-2012 | 02:20 PM
  #1630
johnbugman's Avatar
does anyone like rpm make a set of a arms or just team associated for the b44.1
johnbugman is offline
Old 03-18-2012 | 04:16 PM
  #1631
UN4RACING's Avatar
I would't do that. Its better the arm breaks than a kick up plate.
Old 03-18-2012 | 04:21 PM
  #1632
Buckaroo's Avatar
Just scored a 44.1 in great used condition with a Novak Ballistic 7.5 and a Reedy saddle pack. Any gearing recommendations?
Buckaroo is offline
Old 03-18-2012 | 04:26 PM
  #1633
UN4RACING's Avatar
18/19 pinion, 81 spur on our track.
Old 03-18-2012 | 06:29 PM
  #1634
Mini8 Menace's Avatar
Default most deff a 6.5
I'm building my 44.1 right now and I'm looking at the new LPR X-20 6.5 turn coming out and i have driven a few 44.1s this past weekend and 6.5 seemed to feel to best and the most common class so go with a 6.5
Mini8 Menace is offline
Old 03-18-2012 | 06:35 PM
  #1635
Default DONT GO METAL SPUR
don't go metal spur it will melt with the pinion and will mess up the spur and pinion gear make them all burred up and if rocks get in there your screwed just a little one have you made sure you motor mount or plate to your motor mount the screws for them being loose they have a tendency to chew up your spur if everything isn't super tight and also spaced properly
