B44.1 Thread
#1441
#1442
guys my 3rd diff gear shot, i put my brakes way down, and my slipper on the loose side.
i bought shims so i can tighten the gears bc there was a slight play when i installed. So which sides should i throw the shims? any tips? also i put a few dots of lube on the gears b4 i close the cases...
#1443
#1444
#1446
Again IMO the Kyosho springs are better. I tried both
#1447
#1448
is it that much better? i'm running black/yellow losis right now. having a tough time trying to pull the trigger on $80 worth of springs for my 2w and 4wds. was gonna go with yellow/white on the 4w and white/gold on the 2w.
#1450
#1451
Ashuras
Tyvm for the reply. I have been running 1/5 and 1/4 scale for many years now. Last time I had a 1/10 scale I was about 14. I am unsure on how the turns on motors relate to KV.With jets I fly we always go by KV to pick how fast we want to spin the fan. I apologize for my ignorance. Should I start with a 19 tooth and go by the temps and performance of the car? I don't want to burn anything up the first 10 minutes on the track.
Thanks again
Thanks again
#1452
I bought them for both B4.1 and B44.1, I haven't tried my B4.1, but on my B44.1 they made a difference. Using the Losi springs was a great improvement, then the stock AE springs, Kyosho springs just feel a bit better especially when I hit the corners and jumps.
#1453
any problems with getting your rear wheel nut on/off? Some locals at my track say depending on what nut driver you have you can run into some issues because the TLR wheel is made for a smaller nut than the B4 uses. So if your nut driver's wall is too thick you run into some issues.
the EDS 11/32 nut driver will fit, too.
#1454
Ashuras
Thanks again
Thanks again
#1455
The mesh needs to be tight enough that you think it is TOO tight, then it should wear in nice.
1Likes
