B44.1 Thread
#1411
Hard braking is the real gear killer. Good slipper setting plus softer brake setting the gears last longer. I put 5 spots of white grease on the gears and shim them tight. 6 shimms on the gear side. It improves natural braking and makes the gears ware longer. Down side is the gears may be louder. I have the slipper set at about 6'' the brakes set so the rear wont lift off the ground. My brakes will upset the kit but not lock up.
Its worked very well for me. I run a 6.5 and soon to be running 5.5.
#1412
From: Conducting aggressive board meetings at my local track
Yes they are adjust the weight depending on the weight of the lipo they run.
Ryan Maifield is using a Reedy 627 which has more runtime and higher C rate than the pack that Cavalieri uses from Orion. So he cuts the ballast weight down some to keep the total weight of the battery plus ballast the same between both set ups.
I tried the 50 (using lead weight for now) grams this weekend while using the Reedy 627 pack. I never added weight before this. I added additional weight for the main to see what would happen, turned out to be a bad idea. I liked the 50 grams better. Totally amazed at how much better the car handled with the weight.
#1414
#1416
Yes, Associated is the only manufacturer of 4wd B44 front wheels. You can also use Losi 4wd buggy front wheels which will fit.
#1417
#1418
#1422
any problems with getting your rear wheel nut on/off? Some locals at my track say depending on what nut driver you have you can run into some issues because the TLR wheel is made for a smaller nut than the B4 uses. So if your nut driver's wall is too thick you run into some issues.
#1424
#1425
hello.. does anyone have any tips or tricks they can help me out with?? im running a tekin rs with trinity d3 8.5t motor.. my issue i am havbing is the buggy is all over the place!!! off the throttle on the throttle.. landing jumps.. on straight aways.. no matter what im doing it is swerving from side to side and bouncing off tubes... does anyone have any set up sheets i could go off of?? i've never messed with anything on the buggy.. so it will all be new to me.. never had to i was winning... now im getting second place i need to do something!!!
1Likes
