Team Associated RC8Be Thread >
Old 03-24-2011 | 10:59 AM
  #4771
Originally Posted by schnellschnell
Sounds like it was assembled on a Friday before a long weekend! Yikes.
Make sure to disassemble all the 'prebuilt' parts and make sure they are right.
Just think if this was a RTR - thing wouldn't even drive.
J
Oh it is so bad they would have caught the CVA axles because the pin will not even get close.
Team T2C is offline
Old 03-24-2011 | 11:12 AM
  #4772
buggy8's Avatar
Originally Posted by slash_me_up
I talked to aka and they said 1/8 is a little big. Thy said go one size smaller and punch two holes. I just mounted mine up and might have made a tiny mistake. Look at the pix below and tell me if it's a big deal or not. Might just make this one a back wheel. The lip is not all the way flat.
I would try to go by the AKA youtube video gluing method and put some more in there, it should stick...
buggy8 is offline
Old 03-24-2011 | 11:21 AM
  #4773
Suspended
I put more glue on the hump and held it down. It fixed it a little but still not perfect like the others. Is it that bad? Will it still be ok for a back tire?
slash_me_up is offline
Old 03-24-2011 | 11:53 AM
  #4774
117's Avatar
117
Ok, I must be mistaken on my hole size. I'll double check my leather punch when I get home. I'm using the second to smallest size. I went by a recommendation by someone from AKA, I believe, here on RCT, so I'm betting it's not 1/8" like I thought. Probably 3/32" or so. I'll measure the punch with my calipers tonight and post up the results.
117 is offline
Old 03-24-2011 | 01:08 PM
  #4775
Suspended
Can anyone look at that picture I posted and tell me if the tire will be ok!?
Old 03-24-2011 | 01:10 PM
  #4776
buggy8's Avatar
it'll be fine.
I have tires I run that have come unglued and got clay in them. I scrape the clay out and put some glue in. work fine.
it may have a small bump in it but it'll work.
buggy8 is offline
Old 03-24-2011 | 01:15 PM
  #4777
Suspended
it'll be fine.
Thanx, I was worried about it being out of allighnment and messing up my axle and stuff.
Old 03-24-2011 | 01:20 PM
  #4778
buggy8's Avatar
if your checking your screws and stuff after racing you'll be fine. These buggies are very tough
buggy8 is offline
Old 03-24-2011 | 01:23 PM
  #4779
Suspended
lmao I'm still in the phase of, when I hit a wall, flip it, graze something anything like that I bring it in and chack for breaks. I'm still not used to how tough these are!
Old 03-24-2011 | 02:31 PM
  #4780
Originally Posted by Ripped
Oh, i am very sorry! I was talking about my body, it has an horrible paint scheme and the painting itself is very bad, but i see it is the same body as yours. Which by the way looks very nice! I forgot to write it in my previous post
Lars in Norway is offline
Old 03-24-2011 | 03:18 PM
  #4781
per4m28's Avatar
If you use a drill bit go with a 1/16" bit as it will close up since its rubber and do the opposite side as well. If you use a punch a 32nd will do fine.
per4m28 is offline
Old 03-24-2011 | 03:41 PM
  #4782
117's Avatar
117
Ok, I measured the opening of the punch, and it's 0.0.76" ID, so roughly 5/64".
Sorry guys, I was way off on my 1/8" quote!!
117 is offline
Old 03-24-2011 | 04:55 PM
  #4783
Suspended
Haha, that sounds a bit better!
Btw, Cherryville, NC is dirt oval only. I found a forum for tracks in the Carolina's. There's quite a few of them. I've posted questions about nearly each location. I'll post my findings once I get responses.
Sarinexia is offline
Old 03-24-2011 | 05:57 PM
  #4784
GreggW's Avatar
I bent my front CVs last weekend at A Main Hobbies. I'm not paying $25 for new ones. They are getting bent back
GreggW is offline
Old 03-24-2011 | 06:09 PM
  #4785
Ripped's Avatar
Ahh ok... Thanks----
Ripped is offline
