Team Associated RC8Be Thread >
Old 10-02-2012, 04:30 AM
  #7456
Boostcreepr's Avatar
Trader Rating: 10 (86%+)
no just a MMP setup.
Boostcreepr is offline
Old 10-02-2012, 05:13 AM
  #7457
Bmr4life's Avatar
Trader Rating: 50 (100%+)
Originally Posted by Boostcreepr View Post
Can you put a Brushless 540 motor in the RC8BE just to get you by while the MMM is out for repair??
You can, but you just have to gear it properly. You top speed will be a lot slower. Just watch the temps.
The size of the motor pretty much just dictates how easily it can move the vehicle. A small motor can be put in a larger vehicle, the gearing just has to be changed to match.
Bmr4life is offline
Old 10-02-2012, 07:27 AM
  #7458
R40Victim's Avatar
Unless its something like a 6.5 or lower turn. Then no amount of gearing will make it work. On top of that you have to be sure it will handle the voltage you intend to use. I wouldn't put more than a 17.5 in something that heavy, and maybe 3S.
R40Victim is offline
Old 10-02-2012, 07:33 AM
  #7459
Bmr4life's Avatar
A 1/10 motor under 4000kv would definitely work on 3s geared down. That's what people used to use back when the first 1/8th conversions were being done and Castle Creations hadn't yet made their 1/8 motors.
Bmr4life is offline
Old 10-02-2012, 07:49 AM
  #7460
R40Victim's Avatar
I actually use a 5200 Kv motor in my 4WD SCT on 2S. That's geared very low(11T pinion) and my Hyper 10 probably weighs about 2 lbs less than my RC8. He can try it, but I wouldn't recommend it. My motor gets into the mid 160s F during the summer, and I'm pretty easy on the throttle most of the time.
I also had my 8ight E setup to run about the same temp range. I drove it for years without issue(Castle 2200Kv system on 4S). I let another guy who's much more aggressive with the throttle drive it... he thermaled in about 5 minutes.
He might get away with it, and he might not. I always try to stay in a super safe range when making suggestions to people that I've never seen drive.
Old 12-29-2012, 10:34 AM
  #7461
I'm a new proud owner of this buggy. I got it last night from a friend who works in a LHS. It needs a little work but runs good. It has a hpi rage esc and losi excelroin 1700kv along with 4s custom made lipo battery. Will post pics when I'm allowed to. Question, does any Rc8 spec body fit?
Mr.JayDeeM is offline
Old 11-21-2016, 02:35 PM
  #7462
hey all, been a while since did any buggy driving/bashing ( with my 8,2e )
Now I can get a great deal on a nitro rc8b , but I'm a electric guy all in.
Is there any 'rebuild' kit done, ore anyone drew up a parts list on what needed to install a brushless motor in this buggy.
Probably been up for discussion many times by now since the release , but any pointers would be great. Thanks
Attached Thumbnails Team Associated RC8Be Thread-14937476_10154556937650132_7332422377418031199_n.jpg   Team Associated RC8Be Thread-14947823_10154556937745132_5918849235295010726_n.jpg
maxmekker is offline
Old 01-10-2017, 11:43 AM
  #7463
gmintimidator's Avatar
gmintimidator is offline
Old 01-10-2017, 12:39 PM
  #7464
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by gmintimidator View Post
How much difference does the Gullwing arm and Tower make? I got a sweet deal on a b6d so I grabbed it. I've got the car mostly converted to the stock b6 setup. The arms and tower are in transit but I race before they will arrive.
The other item I'm on the fence about is the gear drive. Ran oval back years ago on carpet with a diff and locked Slipper. What does the gear diff do over the ball for the high traction on carpet?
Definitely try the tower and gullwings on the RC8Be, makes a big difference!
Jmuck69 is offline
