RC10B4.1 FT/WC
Old 04-24-2012 | 11:42 PM
  #14026
Originally Posted by NitroLuver
any body running the avid springs? I looked at the list It looks like i'd be starting white all around and seeing what happens...however that's 51 bucks on springs lol
White front Yellow rear is what the avid drivers have been testing
Chase1472 is offline
Old 04-24-2012 | 11:44 PM
  #14027
oh ok, I think I am gonna give the buggy a try stock and then work from there.
NitroLuver is offline
Old 04-24-2012 | 11:51 PM
  #14028
car feels pretty good with the wolfpack... seems to make the car feel more numb than with the full sized battery? 7.5 and the 25c has a great feel.
SmItH_aLeX is offline
Old 04-25-2012 | 06:03 AM
  #14029
madweazl's Avatar
Originally Posted by Autocratic
Remember, the B4 internal drive ratio is different than the 22. You can't assume that gearing the same will create equal acceleration and speed.
81/23 sounds like a good start with the 8.5.
I had accounted for that. I run 22/76 on the 22 which gives me an 8.39:1 FDR and the 23/75 in the B4.1 would give me an 8.47:1 FDR. The transmission IDR basically equates to 1t on the spur (2.6 vice 2.43 on the 22). I'm certainly not opposed to giving the 81 a shot (which would bump it up to about 9.15:1 with the same 23t pinion), was just curious if there was a specific reason the 81 seemed to be the popular choice due to motor placement. I typically try to keep the motor forward to decrease polar moment but some vehicles actually like the weight further back.
madweazl is offline
Old 04-25-2012 | 07:14 AM
  #14030
EvanAZ's Avatar
Originally Posted by EvanAZ
I just posted this in the FS forum, we are doing a fund raiser to help get some additional trucks/buggies up and running for our Cars-4-Kids Program.
http://www.rctech.net/forum/r-c-item...l#post10642304
Screw kits for the B4 and T4 and I think almost enough for the SC10. $15 ea. or 2 for $28 shipped. It is a fund raiser and all money will go directly to the program.
Vince
Still have a few left.
EvanAZ is offline
Old 04-25-2012 | 10:21 AM
  #14031
zeakemedia's Avatar
I am using 26/75 with my 8.5. I can pull buggies that have 7.5's in them and it doesn't run out before the end of the straight. Temps are more than fine. I will eventually try the 81 tooth spur but I like where I am at right now.
zeakemedia is offline
Old 04-25-2012 | 10:54 AM
  #14032
t0p_sh0tta's Avatar
Same here. 26/76 with an Orion grey can. It's freakishly fast, yet so smooth that it feels slow.
I thank Mr. Deverode for the gearing suggestion. Had it dialed straight out of the box!
t0p_sh0tta is offline
Old 04-25-2012 | 11:01 AM
  #14033
madweazl's Avatar
The Reedy Sonic I'm running doesnt seem to have near as much torque as I'm use to feeling in other 8.5s. I had to gear down 2t on the pinion from my Tekin 7.5 to get any bottom end out of it (was having a harder time with short run up jumps than the 17.5s ).
madweazl is offline
Old 04-25-2012 | 01:05 PM
  #14034
Yea I have an 8.5 as well and it doesn't seem to have a bunch of bottom, I ran a dualsky 7.5T on my 22 24/76 and that thing pulls hard and never temps over 150! I am gonna start my buggy off stock and then eventually switch to mod..I may run the 8.5 in favor of the softer bottom..
Old 04-25-2012 | 01:26 PM
  #14035
Jmuck69's Avatar
I am ruuning 24/78 and it feels slow. Boosted 13.5's are running right along with me. I see Cav runs 21/78 with 7.5's so maybe 22-23/78? I have the Orion VST 8.5 with Orion R10 Pro. Any suggestions?
Jmuck69 is offline
Old 04-25-2012 | 01:32 PM
  #14036
Barrett50.cal's Avatar
has anybody put the new vts slipper for the sc10 4x4 on there b4.1 yet? i tried it and i like it. i think accelerats faster.
Barrett50.cal is offline
Old 04-25-2012 | 03:28 PM
  #14037
Default New to B4.1
What parts I need for use BB springs.
IVAN RM is offline
Old 04-25-2012 | 03:29 PM
  #14038
You guys need to take into consideration why they are running a 78 or 75 or 81 spur. It's not to achieve a gear ratio. It's to adjust the weight bias and make the car handle differently.
I tried 75, 78 and 81. Always went back to 81. It's a prefrence thing. Here's what you need to remember though. If you like the way the car handles with a 75 and want to run the same gearing I run with 81, you have to LOWER your pinion by 2 teeth. 3 teeth on the spur = 1 tooth on pinion. So the difference between 75 and 81 = 6 teeth, or 2 teeth on the pinion.
I ran an LRP X12 8.5T geared at 23/81. So if I wanted to switch to the 78 spur, I would be running 22/78.
Hope this helps!
Bob Barry is offline
Old 04-25-2012 | 03:33 PM
  #14039
AngryRog's Avatar
It's been covered alot. Use the search function...
AngryRog is offline
Old 04-25-2012 | 03:38 PM
  #14040
Nakzter's Avatar
Default Shock Limiters?
Hi. I am new to the hobby and been researching and looking at the Factory Team Pro's setup sheets and they have limiters. I tried searching and googling if there is part for this and or how do you set/install the limiters? Also if the setup sheet is saying 1mm. Does that mean 1mm off the gound or? Thanks in advance and sorry for the newbie question.
Nakzter is offline
