RC10B4.1 FT/WC
Old 03-17-2012 | 04:20 PM
  #12856
Guest
Originally Posted by Bob Barry
I was told Rips were the most aggressive of all the ribbed fronts. Keep that in mind.. If the track grooves up a lot, try a treaded front like a scrub. Have a set of Flipouts ready for morning (or night) when moisture is up.
You also will benefit by having a set of tires, like M3 holeshots, with std foam. They will be softer and give you more bite. Just remember, when the bite comes up, they could make your lap times slower because you will 'bind' in the turns. That's when you switch to the closed cell. I'm also gonna assume that 8th scales are gonna blow that track out so you may have to run those goosebumps LOL
BOB CAN I RUN THE 4WD FRONTS ON THE 2WD FRONT RIMS????? ON THE
B4.1?????
LOSIRACER77 is offline
Old 03-17-2012 | 04:43 PM
  #12857
B4.1?????
ROFL if you only knew.
Just before this year's motorama, I converted over to hex rims, so I had to glue up all new tires. I went through and glued up a bunch of sets at once... well one of the sets of front tires were actually mispackaged. They were 4wd fronts. I didn't catch it and ran the first day of racing like that and got heckled pretty hard for the next day or so LOL. Noob move on my part.
anyway, yes, they worked but obviously not as good as reg ones LOL.
I still don't believe I did that..... thanks for making me relive the stupidity
Bob Barry is offline
Old 03-17-2012 | 04:51 PM
  #12858
Guest
THE TRACK IS A 1/8 SCALE TRACK?
Old 03-17-2012 | 05:15 PM
  #12859
Guest
Default bob barry
our track there was dry an a little wet in spots.
i like the ripps in the front but had a push in the entry of the corners,
i do have some double dees, flipout and goosebumps rear order and grooves for the front, i was wanting a treaded tire for the front also?
we start racing during the evening but the track gets wetter at night by itself.
Old 03-17-2012 | 05:30 PM
  #12860
treads up front may make the car push if you get more fluff on the line or if you get out of the line. Flipouts work great on wet tracks. I never liked holeshots on wet tracks. AKA Impacts are good too but only when it's pretty swept, like first run after they clean the track off. If the track stays consistent, just try a couple different things until you nail it.
Old 03-17-2012 | 07:26 PM
  #12861
vr6cj's Avatar
On my narrow chassis thing...
YEs it has flex side to side but I dont think as much as you guys think. Feels more then stock but not a ton. I have both to compare. The bracing holds it pretty well. The front to back is almost gone. Here's a pic of the bracing I did on the sides. Like I said before...If it sucks then back to stocker. This is a old chassis too. So just been a fun rainy day prodject.
vr6cj is offline
Old 03-17-2012 | 08:12 PM
  #12862
Guest
[QUOTE=vr6cj;10480889]On my narrow chassis thing...
how wide does the chassis got to be?????
Old 03-17-2012 | 09:03 PM
  #12863
idrummerboy13's Avatar
to all guys running c hubs... r u running 2.5 or 3.0 of toe? I have a bad push no corner speed what so ever...A blocks felt better on my old car...
was running no washers under front ball stud but i added one to make it a little more aggressive into the corner..
idrummerboy13 is offline
Old 03-17-2012 | 09:12 PM
  #12864
Guest
how much anti squate do u have??
Old 03-17-2012 | 09:28 PM
  #12865
2 degrees, no washers under shaved u brace. #2 pistons, 30 weight rear oil, 32.5 front. 2 limiters around. Yellow bb losi rear, orange fronts..
Old 03-17-2012 | 09:30 PM
  #12866
Guest
R U RACING ON A IN DOOR TRACK??
Old 03-17-2012 | 10:06 PM
  #12867
I was running 3.0 toe and 2.0 anti. I tried A blocks a few times but it always made my car feel broke. Now couple other guys like A's... it's all prefrence
Old 03-17-2012 | 10:12 PM
  #12868
Guest
i was racing at a indoor HI TRACTION track, i had to put 1.750 of lead near the servo and 1.500 in the rear for the car to feel good??
Old 03-17-2012 | 10:17 PM
  #12869
Guest
Default weight
guys i just dont think we have enuff lead in the cars, these car was made around 6-cell 3300 -4200 packs then u still had to add weight then but not as much.
Old 03-17-2012 | 11:04 PM
  #12870
SoccerSting's Avatar
Well you could cover the bottom of the chassis with those lead weights that have the sticky stuff on one side. Then cover that with a chassis protector.
SoccerSting is offline
