RC10B4.1 FT/WC
Old 05-06-2012 | 05:24 PM
  #14356
Originally Posted by JohnB
Are you running boosted or blinky mode?
I am geared at a 72/31 in blinky mode on our local track. 75'x65' indoor. A couple weeks ago at the April Fool's Classic where boost was allowed I ran preset boost #3 at a 72/32. Watch your temp and keep gearing up until you hit about 140-150* then gear down for feel if want to.
Actually I will be running my tekin rs pro with my stock rtr3300kv motor so I will join mod class so I don't have limitations on timing I will eventually get a 10.5 reedy sonic when I get money? With a sensorless motor can I run timing and boost an stuff even
chancejeff is offline
Old 05-06-2012 | 05:36 PM
  #14357
20 SMOKE's Avatar
no,you will be in dual mode so set timing advance around 90,what size is your track
20 SMOKE is offline
Old 05-06-2012 | 06:24 PM
  #14358
mxracer458's Avatar
In blinky you always run a taller pinion,if you were running boosted you should have been in the 26-28 range in pinions
mxracer458 is offline
Old 05-06-2012 | 06:46 PM
  #14359
It's a smaller track usually the top times with it being fasted paced are at 14-15 sec for mod buggies at coyote hobbies
Is dual mode where it's sensored and sensor less and so wait can I run boost and timing in my rtr 3300kv reedy motor
Old 05-06-2012 | 06:54 PM
  #14360
20 SMOKE's Avatar
its a sensorless motor so you will be in dual mode,you need a sensored motor to be in the timing(boosted)
20 SMOKE is offline
Old 05-06-2012 | 06:59 PM
  #14361
Oh ok so I've looked at it more so I have to run in dual mode which is sensored and sersorless because my motor is sensorless and I can't add boost nor turbo because I'm not in sornsored only mode but can still adjust timing and the rpm start and end point for timing. Correct me if I am wrong
Old 05-06-2012 | 09:18 PM
  #14362
idrummerboy13's Avatar
Any one who uses the night fox ftw body
does the xl fit on the 8mm chassis? I am making an order at avid and the 8mm version is out of stock and would rather just make one order.
I don't mind extra cutting but will it work out?
idrummerboy13 is offline
Old 05-06-2012 | 09:22 PM
  #14363
The regular Night Fox fits perfect. The XL leaves a gap on the backside of the chassis. Although you would have to wait and order twice, you will be happier with the Non-XL Night Fox.
dirt_oval is offline
Old 05-06-2012 | 09:45 PM
  #14364
Amainhobbies.com had them the other day.
zipperfoot is offline
Old 05-06-2012 | 10:21 PM
  #14365
skrichter's Avatar
Originally Posted by kdub
What pistons and shock locations were you running? I assume AE shock oil.
I've attached my West Coast RC setup which works at almost any indoor track. On the front end, I also run #2, 30wt with 3 limiters and outside on the front arm. For this case, I liked the inside arm setup with 32.5wt. If you get too thick in front, it can throw off the balance in jump landings, so watch out.
I've found that with the AVID springs, you can run thicker oil that you couldn't run before with the kit springs, and the car still can manage the small bumps, but then it really helps the jumping/landing. AVIDs handle different than the Losi due do being thicker wire and more coils. In the rear I've tried GHEA #3 with 27.5, AE #2 with 32.5, and my current setup and all are very close in handling.
CVDs are noted in your setup. What's the case for them vs. CVA's?
skrichter is offline
Old 05-06-2012 | 10:27 PM
  #14366
CraigMBA's Avatar
Default Black vs White shock bushings
A few pages back, somebody mentioned the white spacer being the solution to getting V2 shocks to not leak. Since I've never ran any (I still use V1 shocks, if you can believe that) I measured my V2 shock bushings on my new B4.1, vs the white ones from the V1 shocks.
The V2 bushings (black) are .140", the V1 bushings (white) are .125".
You can either hunt down the white bushings or sand down the black ones on a piece of sandpaper to length.
Hopefully this will end that whole mess of leaking V2 shocks. File down those bushings, people!
CraigMBA is offline
Old 05-07-2012 | 04:50 AM
  #14367
Coscia's Avatar
I've been driving this buggy (my first buggy) for about 3 weeks, can't believe what I've been missing out on! What a blast! Great info on here, thanks everyone
Coscia is offline
Old 05-07-2012 | 05:56 AM
  #14368
LOSI123's Avatar
Originally Posted by pink_sleeve
I've never saw acetone damage wheels before. Tires and foams yes. I've used acetone on all 3 of the wheels you have listed and many others and never had a problem.
Thanks,
I have had duratrash rims melt in acetone and also some onroad ones, so I thought i would check
LOSI123 is offline
Old 05-07-2012 | 06:46 AM
  #14369
The Key with Acetone is it's the fumes that do the work so just put a set if tires in a sealed container and put the acetone in a dish just so it will evaporate but the liquid not touch the tires
works well for me
I leave it overnight and then just peel the rubber off the rims
jdeadman is offline
Old 05-07-2012 | 11:03 AM
  #14370
zeakemedia's Avatar
So how do I get the rear inner hub bearing to quit coming apart? I am using Avid bearings so I know that isn't the problem. When I put the crush tubes in the bearings, and axles, "float" quite a bit in the hubs. Is this OK?
zeakemedia is offline
