RC10B4.1 FT/WC
Old 02-28-2012 | 01:12 PM
  #12121
those big bores look legit! want a set now
derbrylac is offline
Old 02-28-2012 | 01:55 PM
  #12122
STUBYSLAP31's Avatar
R/C Tech Elite Member
Originally Posted by deftones4012
Found this picture on the Jconcepts blog page. Do you see what i see???
Numendahl, hartson, and cav have the three sets they are testing
STUBYSLAP31 is offline
Old 02-28-2012 | 02:01 PM
  #12123
That's not true, there are more sets out there that will be showing up very shortly.
Kave is offline
Old 02-28-2012 | 02:05 PM
  #12124
AE, pls make sure they do not robb!!
GuiltyByAssoc is offline
Old 02-28-2012 | 02:09 PM
  #12125
Jack Smash's Avatar
Does anybody know the part numbers to run big bore springs on a B4.1?
Jack Smash is offline
Old 02-28-2012 | 02:11 PM
  #12126
bilster44's Avatar
Same part numbers as the ones you have on your car already.
bilster44 is offline
Old 02-28-2012 | 02:12 PM
  #12127
Jack Smash's Avatar
Darnit Bill, you ruined my fun
Old 02-28-2012 | 02:17 PM
  #12128
jirish617's Avatar
Originally Posted by Matt Trimmings
That is not a tuning option as far as forward / back. The carrier is meant to be ran in the back position (spacer in front) when running inline axles to maintain the correct wheelbase.
Originally Posted by bilster44
The big spacer goes behind the caster block in the front arms when you are using the "stock" trailing steering spindles.
HA! news to me, this whole time i've been running in-line axles with the spacer in the back...will I see handling changes now when I move the spacer to the front? And what is the issue of keeping it in back with the in-line axles?
jirish617 is offline
Old 02-28-2012 | 02:33 PM
  #12129
onefast8's Avatar
Originally Posted by Bob Barry
ME!
best way to clean your car
Orange Pledge > WD40
onefast8 is offline
Old 02-28-2012 | 02:35 PM
  #12130
Matt Trimmings's Avatar
You move the caster block back with the inline axles to maintain the correct wheelbase. you were basically running a longer wheelbase if you had the block in the front with the inlines.
Matt Trimmings is offline
Old 02-28-2012 | 02:46 PM
  #12131
jirish617's Avatar
so is it possible that my car will corner a little bit better then? it pushes a tad bit more than I'd like
Old 02-28-2012 | 02:53 PM
  #12132
Should, the inlines tend to make the steering more aggressive.
Old 02-28-2012 | 03:00 PM
  #12133
makaluch's Avatar
Got one forward and one back I'm using the SC10 steering block and longer axles for the hex adapters. Trail doesn't seem to change from stock with the SC10 block.
Forward carrier lowers the angle of the top link and raises it (relative to a level arm chassis roll center), also lowers ride height with level arms and increases wheelbase, not to mention bump steer and small link length changes. Back, well, the opposite I haven't found a discussion aimed directly at that and I can't find pictures, setup sheets, or instructions that talk about it explicitly. It's an easy swap but just wondering...
EDIT:...nevermind. I'm an idiot. Forward carrier with trailing axles, back with inlines. Sound right?
makaluch is offline
Old 02-28-2012 | 03:06 PM
  #12134
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Originally Posted by Blue Screw
BIG wins... sorry there chassi slapper... but im over that point i rather help others from what was showed to me.. but then there hardhead knuckle heads like ur self who just wont listen... or take advise...like glueing servo savor..hmmmm..
And sorry to put u on blast but
REMEMBER I FORGOT MORE THAN U KNOW!
And to think, this is how a SPONSORED driver speaks to hobbyists like myself in an open forum. And with that type of punctuation and spelling...
To think I actually had your back on here a few months ago when you first started posting. Ok, if that's how you want it.
You're not over any point besides really not being able to put the laps down. Hence your lack of attendance at the tracks. At least the tracks where there is real competition.
I will never doubt your willingness to help others and your love of the hobby, but let's be honest, there's the old saying "Those that can not do, teach".
As far as me being a hard head and a knuckle head as you put it, I never denied the fact gluing the servo saver will work. It's just something I'm not sure my driving skills are up to, after all, I can put the front end into the pipes with the best of them.
I learned some things at Motorama from AE sponsored drivers who actually PUT THEIR CARS ON THE TRACK. And, guess what? I actually saw a difference in the cars handling. None of what I learned had anything to do with what you told me.
For the record, I highly doubt you forgot more than I know.
I'm not sorry for putting you on blast just now.
Now, back to our regularly scheduled B4.1 programming.
SpraydbySprague is offline
Old 02-28-2012 | 03:08 PM
  #12135
brent701's Avatar
Who on here is running in line axles and the +8mm chassis?
How is your entry into the corner steering?
brent701 is offline
