RC10B4.1 FT/WC
Old 02-21-2012 | 10:13 AM
  #11686
DaveW's Avatar
Originally Posted by Wild Cherry
White Teflon spacer fits(#6440) , no sanding needed.
smoother then the black spacer ...
+1
Works great, fits perfect.
DaveW is offline
Old 02-21-2012 | 10:14 AM
  #11687
bilster44's Avatar
Does the old style white spacer hold the oil well too? Is it thick enough for that?
bilster44 is offline
Old 02-21-2012 | 10:17 AM
  #11688
DaveW's Avatar
O rings hold oil... the spacer supports the shaft.
DaveW is offline
Old 02-21-2012 | 10:36 AM
  #11689
Does the +8MM chassis benefit UK drivers who race on Astroturf? Or is it better purely for the clay drivers?
timee80 is offline
Old 02-21-2012 | 11:04 AM
  #11690
Just1More's Avatar
IIRC it's nylon and doesn't really support the shaft as the OD is too small, it's just a spacer for the O rings.
I'd say better all around. If you're the the only one at a track running 8mm because the others haven't caught on, you're likely to have the competitive edge
Just1More is offline
Old 02-21-2012 | 11:23 AM
  #11691
This may have been covered, but I see alot of people waiting on losi spring cups. For those thar don't want to wait use rpm #73152. They work as well, just not quite as fancy as losi cups, but no modification needed as far as gluing cups.
msave is offline
Old 02-21-2012 | 11:25 AM
  #11692
Originally Posted by jirish617
What kind of servo is he running?
Savox
Losi57 is offline
Old 02-21-2012 | 12:00 PM
  #11693
Just use the traxxas ones that what I did and they work fine they are a little tight but they work
JoshCorti11 is offline
Old 02-21-2012 | 12:02 PM
  #11694
DaveW's Avatar
So.. what supports the shaft then?
Does the hard metal shock body support the shaft?
The piston and the spacer combined keep the shock shaft "centered" and safe from metal contact (except in extreme conditions).
Yes, the spacer ID is larger than the OD of the shock shaft... it has to be for proper shock action (the same reason the piston isnt tight in the body bore). While the spacer DOES space out the o rings... it is NOT its primary purpose.
DaveW is offline
Old 02-21-2012 | 02:18 PM
  #11695
jirish617's Avatar
Originally Posted by Losi57
Savox
man, thats depressing, hope it dont happen to me
jirish617 is offline
Old 02-21-2012 | 02:29 PM
  #11696
gamedog1966's Avatar
I keep blowing stock bearings in all my vehicles, sc10, b4.1 and t4.1 and I would like to know what is a good brand of bearings to get for them that is very smooth and have a long life span. And I'm running on indoor clay
gamedog1966 is offline
Old 02-21-2012 | 02:45 PM
  #11697
t.mathewson's Avatar
I was told to just get the cheaper avid ones and replace as needed.
t.mathewson is offline
Old 02-21-2012 | 02:51 PM
  #11698
yeah aren't they like a buck a piece or something like that....... just grab 20 at a time and you're good for a while
Bob Barry is offline
  #11699
Littlejohn Dsgn's Avatar
I have never had an issue with Avids bearings
Littlejohn Dsgn is offline
Old 02-21-2012 | 02:53 PM
  #11700
Default Shock Oil Comparison
Can anyone give me a number value for how much thicker losi is compared to associated? I saw a chart from 2005 and read a conversation where people said losi is about 2.5wt thicker than ae. Is this pretty accurate still?
