RC10B4.1 FT/WC
Old 12-29-2011 | 11:52 AM
  #9001
idrummerboy13's Avatar
Originally Posted by RcJohn17
and look he has barcodes ! haha
those are bks in pink, we havent tried gold but green codes sucked bad.
Originally Posted by YankeeFan123
That is muh more conventient considering that you have to start up your laptop, plud in the cord to both your laptop and the esc and then do your adjustments
it comes with a small card and cord that goes into the on off switch, no laptop needed with viper. Everything is on the card which is included with the setup.
some guys say they are bad when they havent even tried, just a shame at the track many question my use but it is a flawless speedo.
idrummerboy13 is offline
Old 12-29-2011 | 12:20 PM
  #9002
RcJohn17's Avatar
good info guys ! Helps out we will see what I do , calling to see what I can get it for right now.
RcJohn17 is offline
Old 12-29-2011 | 01:45 PM
  #9003
Asharus's Avatar
Originally Posted by idrummerboy13
mine were untill barry showed they slip over the bottem part of the collar, than they dont even seem to be there.
friday u can try it i think you will like the springs but im trying some changes.
ah that explains it
ive tried the gold codes and they feel just as good as the pink bks we run now. at least that's how i remember it. then again i've never TQd and won with gold codes.
Asharus is offline
Old 12-29-2011 | 01:48 PM
  #9004
B.A. Racer's Avatar
around here nobody runs barcodes anymore...alot have switched over to losi pink
B.A. Racer is offline
Old 12-29-2011 | 02:29 PM
  #9005
-WHEELMAN-'s Avatar
Originally Posted by Asharus
ah that explains it
That may be because you race beginner now?? J/K!!
In So Cal we are still running version 1 gold barcodes a lot on our clay tracks. Some are running pink BK Bars but not a lot! There both good but seems like Bar Codes have a tad bit more forward bite.
-WHEELMAN- is offline
Old 12-29-2011 | 05:31 PM
  #9006
ah that explains it
yup!
Hahahaha you won the c main on tuesday angelo. and were they the v2s?
v2 greens bad, v1 golds on 4wd were pushy, will try on 2wheel.
Old 12-29-2011 | 05:37 PM
  #9007
brent701's Avatar
I run barcodes Green V2's and love them... When I get a good amount of traction it will push.
the Double dee's do not do that... they just let go a little.
brent701 is offline
Old 12-29-2011 | 05:49 PM
  #9008
Kraig's Avatar
Super Moderator
Have any of you tried the blue compound bar codes?
Kraig is offline
Old 12-29-2011 | 06:22 PM
  #9009
20 SMOKE's Avatar
i have some,good grip i don't have anything else to go by but others i ran against ran clay or green compounds
20 SMOKE is offline
Old 12-29-2011 | 07:39 PM
  #9010
guys at the track(med high bite)
say they have nice forward bite, push out of the corner but are loose on larger faster turns. Bk bars pink seem to be nice, beams are ok, i am 3/10 faster overall with bks and when the are flat thats when they are dailed.
Old 12-29-2011 | 08:48 PM
  #9011
yea shorty pack setup was very pushy had lots of bite. Tried a.e springs and they do feel real good, black in back brown in front
will try #3 pistons 25 oil 2 limitiers rear
#1 35 oil 3 limiters.
Black a.e springs.
Old 12-29-2011 | 08:58 PM
  #9012
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Black a.e springs.
You realize the whole point to the shorty pack is to gain more freedom of movement right?
T-BirdJunkie is offline
Old 12-29-2011 | 09:04 PM
  #9013
Teambcw's Avatar
Break it down for the new guys T-Bird.... you could explain it better then me..
Teambcw is offline
Old 12-29-2011 | 09:11 PM
  #9014
mod guys say they make it react quicker and move in the turns faster, and it makes car more forgiving.
i thought the shorty pack setup would push to begin with because it would make up for the lost weight, i found many weren't changing there setup much compared to brents thelkie's
Old 12-29-2011 | 09:29 PM
  #9015
Hey is this the preferred slipper pad now?
http://www.amainhobbies.com/product_...pper-Pad-Set-2
or is it
http://www.amainhobbies.com/product_...pper-Pad-B4-T4
Bob Barry is offline
