RC10B4.1 FT/WC
#9016
Hey is this the preferred slipper pad now?
http://www.amainhobbies.com/product_...pper-Pad-Set-2
or is it
http://www.amainhobbies.com/product_...pper-Pad-B4-T4
or is it
#9018
mod guys say they make it react quicker and move in the turns faster, and it makes car more forgiving.
i thought the shorty pack setup would push to begin with because it would make up for the lost weight, i found many weren't changing there setup much compared to brents thelkie's
the short pack makes it react quicker yes, but most of the time that means it is harder to drive and more mistakes, it can be a bite more forgiving in a rough section.... The long one will have more corner speed on a track with more traction, more run time, more traction in some cases but can also act like swing weight once the car breaks loose... there is no right answer. Many of the locals have both on hand and it is more of how the traction is that day and is a final setup deal.
#9019
or is it
or is it
#9020
From: Norwood, OH...and CCRCR and The OhioRCFactory
ThunderbirdJunkie hasn't yet had much opportunity to play with the shorty pack, it's only got a few runs on it, but these are his initial impressions of it. Theilke's setup was ThunderbirdJunkie's baseline when he rebuilt his car with the +8 chassis and shorty pack (and brushless setup, lol, but that's a whole 'nuther story) lacked rear side bite and was really really touchy with the steering and had almost nothing on exit.
There is good and bad to both the long and short packs....
The other side of it, perhaps ThunderbirdJunkie simply doesn't drive the same as Theilke does, and has since started changing his setup accordingly.
Stupid end of the year holidays interfering with track time
Oh, and take all of this with a grain of salt.
#9021
Will try :P
It all depends. A lot of the FT guys (IE Theilke) are running their batteries way far forward. For somebody on ThunderbirdJunkie's level, the weight that far forward makes the car more reactive on initial steering, but actually lengthens the polar moment of inertia (do some reading) making it a little lazy in transient maneuvers (it steers awesome initially, but it's a bit oafish in switchbacks and chicanes) despite having awesome initial steering. Moving the pack back would help with both calming down the initial turn-in and the transient (left to right to left, etc) turns a little more doable.
But you can also position the bulk of the weight further backward making it a little easier to drive. One thing that confused ThunderbirdJunkie about Theilke's setup in particular is the additional sticky weight so far back on the chassis, but the battery so far forward. Seems counter productive.
#9022
#9025
I like the V2 for the extra corner speed it has compared to the standard V1 bar code tire .
We run both at Trcr with great results , but most are using the v2 .
Personally I feel its not the tread pattern but rather the compound on the v2 gold is softer than the v1 gold .
i know , maybe I'm wrong
but , I can feel & smell the difference between the two....
.but , I can feel & smell the difference between the two....
#9026
BITE is very nice med to high, always swept and clean during racing. Bk bars in pink are burned, gripped, wd40, gripped after every run to keep them soft but they wear out fast! but this is what all are doing. Bald seem to work well untill it gets colder in the place. Will try gold v2s on 2wd i have v1s. Green v2s may work if I work them a little bit. Will try during different conditions.
#9027
Quick question. I just bought the gear diff (and case) to experiment with.. Is the gear ratio the same as the ball diff? Also, do you all recommend using the Assoc black grease, AcerGoo sytnetic grease, or diff oil? The track is a very high bite, indoor clay that is very well maintained and now that it is winter, very cool inside. The current track config has a quad, a triple, 3 doubles, steps and a steep sharp hairpin. thanks
#9028
I'm gonna race on carpet so i switched the rear hubs of my B4.1 to the plastic 0* hubs.
Do i need to change the crush tube too? I think there is a grinding sound coming from within the hub, like something is rubbing on the bearings.
#9029
no, the golds i tried were V1. i was not gripping the tires back then though, just cleaning with water and simple green. i felt that the gold codes had more side bite than the pink bks. then someone yelled at me and told me to use gripped bks. once i started gripping them they had better side bite than the gold codes, so that's what ive been using since and haven't tried anything else.
#9030
yes it is the same gear ratio,
I use 3,000 wt gear diff oil.
I am hearing a few people locally that are running gear diff in their buggies are running 2 of the 4 small gears instead. Less rotating mass I am told.
I have not tested it yet. I don't feel like removing the tranny to do it till I need to rebuild it.
