RC10B4.1 FT/WC
Old 02-07-2011 | 03:02 PM
  #1501
Ed237's Avatar
Its legal. I measured it and the wheelbase on the BT4 is the same as the T4 (288mm).
For comparison: The new TLR 22 is the maximum wheelbase at 292 which is 15mm longer than the current XXXCR platform.
I was able to fit a Pro Line Vortex body on by trimming the front sides and using velcro on the sides instead of body clips.
Ed237 is offline
Old 02-07-2011 | 03:27 PM
  #1502
You could probably use a J82 body from JConcepts.
It's designed to fit the longer truck chassis.
JW91 is offline
Old 02-07-2011 | 03:39 PM
  #1503
Cameron Kellogg's Avatar
This man is a genius. Problem solved.
Cameron Kellogg is offline
Old 02-07-2011 | 03:58 PM
  #1504
One guy out here not only lengened it but also narrowed it, uses saddle packs side by side and has all the elctronics on the centerline. It works really well.
DG Designs is offline
Old 02-07-2011 | 04:04 PM
  #1505
mellow's Avatar
Similar to a 22?
mellow is offline
Old 02-07-2011 | 04:07 PM
  #1506
yep, just with a lot more glue!
Old 02-07-2011 | 04:09 PM
  #1507
mellow's Avatar
yep, just wih a lot more glue!
If he did a nice job on it, would be interesting to see the difference in handling characteristics between the two..that is if they ever release the 22 to the public before the years out. I for one am waiting on my FT b4.1 to get here
mellow is offline
Old 02-07-2011 | 06:24 PM
  #1508
Thats the one I am talking about. For a DYI project, it came out real clean. He trimmed the back of the body a little long to make up the additional wheelbase. On the track it doesn't look much different than the standard B4's He is the one who said it turned out to be over the limit, but I don't want to offend anyone. LOL
JustMe2 is offline
Old 02-07-2011 | 06:47 PM
  #1509
rcguy76559's Avatar
Originally Posted by vafactor
A pal told me that some of the west coast guys (with other brands of cars) have been putting a truck chassis tub on their buggys to lengthen the wheelbase (which I'm told makes the cars smoother, easier to drive and jump, without forfeiting much if any steering. Has anybody tried this on an AE B4 or B4.1? Is the truck tub a direct fit (just with a longer wheelbase)
I have some info I posted on this on the b4 t4 forum here. Something with another guy had pics with the body. I just used the same body with more velcro to see if I liked the truck chassis.
rcguy76559 is offline
Old 02-07-2011 | 07:00 PM
  #1510
rcguy76559's Avatar
Originally Posted by rcguy76559
well i just tried the t4 chassis with buggy setup. Works pretty well. I would say its alot more stable high speed and in turns. It felt like the more i pushed the car in the turn the more it wanted to turn. I run on a small tight high bit indoor track. I wish it would turn a little sharper. For me it was alot easier to drive but where its tight was alot harder to hold the tight line. About the same lap times just a little more consistent So im just going to run the normal chassis. You guys should try it you might like it more.
I found what I said about it. I would use the longer chassis on an open non tight course.
Old 02-07-2011 | 07:35 PM
  #1511
baneonrt's Avatar
The Proline bulldog B4 body works pretty well with very minor trimming. Check out the pictures of my B4 with it and the T4 chassis.
http://www.rctech.net/forum/8573712-post14034.html
You can kind of see where I trimmed it on the front. Also flattened the nose with a heat gun. I left a little extra material around the rear body mount tab to give it more support. There is enough room on the sides to put some velcro at the flat spot but not closer to the front or at the very back. I use velcro on the sides and a body pin on the front.
Steve
baneonrt is offline
Old 02-08-2011 | 10:09 AM
  #1512
JayL's Avatar
R/C Tech Elite Member
yes you can run truck chassis and the jconcepts body, but
let me just say all the norcal guys doing that got laughed at at the Reedy and changed back
JayL is offline
Old 02-08-2011 | 11:25 AM
  #1513
DaveW's Avatar
Nothin like peer pressure to inhibit experimentation...
DaveW is offline
Old 02-08-2011 | 02:01 PM
  #1514
mellow's Avatar
Might as well buy a T4.1..
mellow is offline
Old 02-08-2011 | 04:00 PM
  #1515
mellow's Avatar
Anybody know if the b4.1/t4.1 kits are metric based or U.S. based? Trying to figure out what sizes ill need for when I get my b4.1
mellow is offline
