RC10B4.1 FT/WC
#7681
I am getting rid of my T4.1 roller and a bunch of tires(9 sets of 4-including slicks). The truck has only seen the track 3 or 4 times. Body not included. Not looking to split this stuff up either. PM me if you are interested.
#7683
thanks Todd, thats with no timing on the esc right? if so that might be the way to go! i have two options on esc's to use, one being a lrp (sxx comp ver1) over two years old, and a rspro if i were to use advance timing in the esc. which route would u go, are u against dynamic timing, or does your stock class run a blinky mode over there? if u had the option of both, would u gear it to the moon with a sxx esc combo, or boost it using a rspro with a way higher fdr than what your running of course!
#7685
You are positive of that Wild Cherry? The reason I ask is because we do not have vertical ballstud hub carriers...and I did not know if it works in the opposite way beings it is inboard instead of out at the wheels...? I do know if you stack them at the hub carrier, then yes, you get more side bite. But inboard on the "U" brace I am confused...
#7686
If you need more traction also consider lighter oil or spring ...
other ways
moving to inside on tower for rear shock , more rear toe
( .5 hub or toe block), softer tire insert , ect ....
#7693
for pinions, i havent had any issues fitting any type of pinion... losi, associated, rr, even a traxxas.
#7694
jc just released the "silent spurs". associated and kimbrough make the standard spurs, some say that the kimbrough spurs are better. some say that kimbrough and associated spurs are the same and that kimbrough makes associated's spurs.
