RC10B4.1 FT/WC
Old 08-09-2011 | 01:28 PM
  #4906
aeRayls's Avatar
Originally Posted by gguertin145
Ok so I was already making them the same with a caliper... I guess where I was going is if the shock is longer or shorter based on how far you thread the ends on wouldn't that affect handling?
You are over thinking this. Just thread on all the way then even them out with calipers. All the way down is the standard but tolerances of parts vary.
aeRayls is offline
Old 08-09-2011 | 01:31 PM
  #4907
gregm's Avatar
Ok so I am just trying to learn so please forgive any ignorance.
Why does it matter so much on travel inside the shock that we use limiters but it doesn't matter how long the rod ends are on the outside of the shock? I must just misunderstand how this works? I thought the limiters to prevent how far the shock can travel? So why allow the a-arms to travel that far anyway by having longer rod lengths?
Limiters or turns of the shock end are both ways of adjusting the down travel of the shock. The total length does effect handling. Limiters are set when you build the shock. Turning the shock end is a quick and easy way of "adding or subtracting" a limiter without tearing the shock down.
swiped from http://users.telenet.be/elvo/
Internal Travel Limiters / Droop / Downtravel
More
(less droop/downtravel)
The car changes direction faster, and corners flatter. It feels generally more responsive.
Adding a lot of travel limiters is only advisable on smooth tracks.
Less
(more droop/downtravel)
Less internal shock spacers give better handling on bumpy tracks, and more and more consistent traction on difficult tracks.
The car also land better after jumps.
The end with the least downtravel will feel the most stable, and the most direct. But try to keep a balance (front and rear end droop about the same), especially on low-grip tracks.
Adding more internal travel limiters is a very effective way of reducing traction rolls, if not the most effective way.
gregm is offline
Old 08-09-2011 | 01:35 PM
  #4908
Thanks for the help!
gguertin145 is offline
Old 08-09-2011 | 01:46 PM
  #4909
916bdogg's Avatar
Thumbs up Likes +1
More
Less
916bdogg is offline
Old 08-09-2011 | 02:09 PM
  #4910
BrentH's Avatar
Thumbs up
More
Less
+1
BrentH is offline
Old 08-09-2011 | 09:19 PM
  #4911
916bdogg's Avatar
Thumbs up AE Is Killer Of All......
Clean Sweeper !
Attached Thumbnails RC10B4.1 FT/WC-images.jpg
916bdogg is offline
Old 08-09-2011 | 09:21 PM
  #4912
zanernator's Avatar
what gearing would u guys run with a 8.5 x-12 in a t4?
zanernator is offline
Old 08-09-2011 | 10:13 PM
  #4913
racer1812's Avatar
Super Moderator
ohh Cherry I would never say you're wrong, we all know that's never the case....
racer1812 is offline
Old 08-09-2011 | 10:23 PM
  #4914
Brad S.'s Avatar
Hopefully the body and chassis help "Finnish" the competition. lol.
Brad
Attached Thumbnails RC10B4.1 FT/WC-racing-119.jpg
Brad S. is offline
Old 08-09-2011 | 10:30 PM
  #4915
racer1812's Avatar
Super Moderator
You run the limo at all yet Brad? PM if you want..why aren't you at the Nat's with the rest of our AE brothers?..LOL
Old 08-09-2011 | 10:42 PM
  #4916
idrummerboy13's Avatar
oh man, used epoxy and made braces with screws coming through and nuts on the other end, withen a lap it was 2 cars lol
I will try my aka thin tire glue, would you guys say fiberglass tape along with thin tire glue and what braces/? They were long braces but the epoxy broke so quick, i let it dry clamped for a day. UGHH i feel like a jerk changing my stuff between chassis.
idrummerboy13 is offline
Old 08-09-2011 | 11:22 PM
  #4917
B.A. Racer's Avatar
your not the only one....even with the tire glue ive seen acouple break within laps...
B.A. Racer is offline
Old 08-09-2011 | 11:37 PM
  #4918
Matt Trimmings's Avatar
I have never broken one of mine....
Matt Trimmings is offline
Old 08-09-2011 | 11:52 PM
  #4919
racer1812's Avatar
Super Moderator
some guys can't glue tires either...just sayin'. I'm working on mine and I'm not scared
Old 08-09-2011 | 11:59 PM
  #4920
Wild Cherry's Avatar
Tech Legend
We took a B-4.8 and did our best to break the thing ...
Moons shots , pole shots , casing jumps, ect ...
Finally broke it by going full speed down the straight into the cinder block wall...
We just glue her right back together with tire glue again .
Wild Cherry is offline
