RC10B4.1 FT/WC
Old 09-17-2012 | 12:08 AM
  #20656
rigor's Avatar
Originally Posted by elex300
Anyone catch the Jcon tires on Cavs car from nats. I guess PL does'nt mind.
He runs PL Suburbs v1's in the rear on both his 2WD & 4WD buggies @ West Coast.
rigor is offline
Old 09-17-2012 | 12:51 AM
  #20657
Has anyone tried the Tini ball studs? Just curious because they look cool and if there is a real performance gain that would be win win.
I run them on all my cars. They have no discernible performance benefit (technically they have lower friction, but it's unlikely anyone could feel a difference), but they do have a distinct longevity benefit. Standard ballstuds get worn by dust/grit while TiNi is so hard that basically nothing you normally encounter wears it. You still need to replace ball cups periodically, but you shouldn't need to replace the stud each time with these. When you swap them, I recommend replacing the ball cup and foam at the same time.
Originally Posted by RcRacer27mx
Some will say they have a performance gain, but I just think they look sweet!
They are pretty nice looking, just like TiNi shock shafts.
Originally Posted by Tradin Paint
Don't think I have seen them. Who makes them?
Associated... I've never seen an LHS that carries them, so you have to order them.
ASC9795 - Long, 0.2"
ASC9796 - Long, 0.3"
ASC9797 - Long, 0.4"
ASC9798 - Short, 0.2"
ASC9799 - Short, 0.3"
For a B4(.1) you need:
ASC9795 x 1 - Bellcrank. Replaces ASC6276.
ASC9796 x 3 - Front shock tower, steering blocks, and U brace. Replaces ASC6277.
ASC9798 x 2 - Servo horn and steering rack. Replaces ASC3981.
ASC9799 x 2 - Caster blocks and rear hubs. Replaces ASC3983.
I have found that you can use ASC9798 in place of ASC9795 with no ill effects, which saves you a pack of ball studs, but the above are the exact correct replacement parts.
If you're running C towers: You can use ASC9798 instead of ASC9799 on the towers. For some reason ASC9799 seems to be sold out most often, so this is an option for those positions.
If you are not running C towers, or switch back-and-forth: You must use ASC9799.
The caster blocks can also use ASC9798, but ASC9799 is the exact same size as the original.
EricJ is offline
Old 09-17-2012 | 04:28 AM
  #20658
Tradin Paint's Avatar
Wow Eric, Thank you for the detail and the time taken to put this together
I see from your post that you do use the foam pads on the ball studs. I took those of thinking that it just caused more dirt/dust to get caught between them and the cup is this not the case?
Tradin Paint is offline
Old 09-17-2012 | 07:22 AM
  #20659
Eli's Avatar
Eli
Originally Posted by rigor
Incorrect. The stock classes at ROAR Nationals were spec tires. Mod classes were completely open.
EDIT: Sorry didn't mean to pile it on you... I posted my response before further reading the thread and other replies.
haha, its all good.
Eli is offline
Old 09-17-2012 | 07:42 AM
  #20660
Brit_racer's Avatar
With the associated big bore shocks coming out i am hoping someone can sell a big bore spring conversion for the B44.1 or T4.1
I think its going to be a little while before i can convert mine over.
Please message me please if you have some for sale.
Brit_racer is offline
Old 09-17-2012 | 07:44 AM
  #20661
vfrninja's Avatar
Hey guys just wondering what a good starting point would be for the avid springs. Front is batch 2 and rear is batch 1. Track is tight, high traction.
I figured I would start with the ones closest to stock to start but thought some of you might have it dialed already.
Thanks.
vfrninja is offline
Old 09-17-2012 | 08:08 AM
  #20662
gamedog1966's Avatar
Do you guys know if the avid and losi bb spring can fit the ae bb shocks?
gamedog1966 is offline
Old 09-17-2012 | 08:20 AM
  #20663
Wildcat1971's Avatar
I am sure they will, but we wont know for sure until get them. Side note, I saw a guy at the track with Losi BB shocks. He was using the 2mm spacer behind the shock bushing. Clearance looked good on the front and the springs were not in the turnbuckles. He had a weird rear configuration, so no idea on that.
Wildcat1971 is offline
Old 09-17-2012 | 08:30 AM
  #20664
Matt Trimmings's Avatar
Yes they fit.
Matt Trimmings is offline
Old 09-17-2012 | 08:34 AM
  #20665
Wild Cherry's Avatar
Tech Legend
Thanks.
V1
Start with yellow ft & back ....
Red, if the grip is med to high
v2 same as above
Wild Cherry is offline
Old 09-17-2012 | 10:00 AM
  #20666
Big Features's Avatar
Hey guys, Check out the new Big Bore shock kits at www.RC10.com
Big Features is offline
Old 09-17-2012 | 10:07 AM
  #20667
Tech Legend
Default AE BB
I'm hearing team drivers get before this Friday , retail available the week after .
Old 09-17-2012 | 10:19 AM
  #20668
I wonder how much of the setups will change due to getting the bb shocks
Old 09-17-2012 | 10:28 AM
  #20669
D.Martijn's Avatar
I got several questions.
I'm studying electromechanics and have to make a thesis (integrated test).
I'm making my thesis about RC cars ofcourse (B4.1 and Savage)
Now, I need to know about what material the B4.1 is made of. Is there anyone that knows this? Yeah, I know plastic but what kind?
Also, other information about materials (motor, shocks, etc etc) which alloys etc.. are much appreciated!
Every info is welcome, you can always send it to my pm's.
D.Martijn is offline
Old 09-17-2012 | 10:38 AM
  #20670
I would contact AE and traxxas. They would probably be able to give you the most information.
