RC10B4.1 FT/WC
Down load a set of the B4.1 Team instructions , most of the parts materials are listed on page 2
go to www.rc10.com for down load intructions
Already have to write 10pages till monday next week
Just send an other email to AE I hope they reply this one
They probably won't provide you with the exact composition of the plastic. Perhaps you could find different lists of plastic's available, what they are made up of, and use that for your paper. Or you could always do a taste test if you have done so already.
Good luck!
Good luck!
may be off topic but.... with the indoor season approaching... lets talk about traction compound.
im down to only a couple of bottles of zip free left. i'm surprised to see that everyone is still on backorder. which leads me to believe that trinity has discontinued it?
what are the alternatives?
Question on front hex conversion for the the B4.1
My car is new and I built it with the AE hex conversion knuckles & axles, with JCon hex adapters, and I have one side that when you tighten the wheel there is a decent amount of bind on one side. The other I can tighten very tight and it rolls fine, the other, it drags.
Ive heard of others with the problem, they just run the wheel on one side not as tight. I would rather just fix / solve the problem but really can't find anything that jumps out as the issue.
Wondered if others might be seeing the same thing or have a fix?
What I received back: Sorry we do not send out that information, it is proprietary information.
Edit: im using gold v1 barcodes
