HPI Vorza Flux 1/8 E-Buggy Thread
#4891
If the stock mount is limited to 18T. How are people using a 26T for 80mph?
#4892
i can tell you that 99% of vorza owners use a pinion between 16-19 teeth and run the vorza off road. your new mount will suit our needs perfectly. the Eliterc mount is great but no one can get one.
#4893
Got it today and installed just now, and it's seriously another step toward easier gear meshing. The only thing i'm trying to sell is the rcm mount so if anyone want, let me know, the ad is in the FS section.
Also, Jeff told me to go to Mr.Mya's for his home-made spacers to raise up the differential mounts and of course diff itself, but he did not seem to come here often anymore , so if anyone has a spare one, i'll buy it from you, too.
Mr.Mya, hello?!!!! Some business here for you
p.s., a bit mad that i already cut the stock receiver box which turned into a total :ugly:, elite mount does not require box mod ;(
another option you could do with your rcm mount is cut off the motor mount and clean it up, flip it around and use it as the other half of your center diff mount. along with the eliterc mount, new rcm center bearing holder and top brace you will have an all aluminum center diff! its actually what i did.
here is a pic if you can see it.
#4894
#4896
ive actually never heard of anyone using a pinion larger than a 21, like i am. eliterc makes a mount for the D8 that MAY allow the use of that size pinion but that mount has been out of stock for about 3 months and they are produced unreliably and most people cant get one. this is why we went out to find another company to produce mounts for the vorza. some are using the tekno conversion for the D8 with comes with a decent mount that allows larger pinions but its a separate piece similar to the stock mount which makes gear mesh a problem.
#4898
Hey guys, I have an elite rc motor mount I am putting up for sale. It's hardly used (shows minor wear). I thought I would let you guys have first crack at it since they are so hard to find. I will take offers via pm. If they come in really low I will just put it in the for sale forums. Mount comes with everything as new including brand new bearing installed. These really are the BEST mounts. Takes literally seconds to adjust your mesh and never moves. Just set it and forget it. I have these on all my rides.
I also have some other race stuff for d8/vorza (aluminum rear hubs, lightened outdrives, cvd's, a-arms, etc) that I will be posting also.
#4899
Elite Rc mount can fit any size pinion with no mods..that is how people are using larger pinons.. It can be used for racing or high speed runs..very strong, simple and quick to change pinion sizes.
#4900
Suspended
80 mph runs will require some serious driving skills. Bigben emailed an article from an rc magazine hitting 100+ mph, and it took a lot of work from what the article stated. The diffs required some serious work, apparently they distribute power very unevenly at those power levels. Foam tires were also used, so plan on buying some really good tires that are going to wear very quickly. I sold my 6s way before I traded the Vorza; 6s seemed to be too much for anything other than speed runs, and dont forget that very high speeds also accelerates wear on any moving parts.
I had my Vorza at 67 mph, and it was more than a handful. Really cool to see for sure, but any mistakes can (and usually does) lead to an expensive crash; the Vorza is durable, but not indestructible.
Don't forget that those going for speed runs usually only get a few tries before needing to let everything cool down. I would try the Vorza on 6s in stock configuration, maybe add an 18t pinion. 60-70 mph may not sound like the ultimate in speed, but it is extremely fast, especially if you are not used to those speeds.
#4901
grid rc mount
Hi rc grid
I drag race my vorza and use a 22t pinion, so that will be great for me, let me know when they are ready?
Cant wait
Cant wait
#4902
HPI support rocks!
Last month the esc in my Vorza died. I called HPI support and they told me to send it in and they would take a look at it. I didn't hear from them for a few weeks so I called and they told me they never received it. Since I didn't have any proof that I shipped it I figured I was out one esc. So I ordered a new mmm on Ebay, end of story. Not really, yesterday I get a box in the mail from HPI. One brand new HPI Blur esc, no explanation, but there was. HPI support rocks!
Jerry
Jerry
#4903
Jerry
Jerry
