HPI Vorza Flux 1/8 E-Buggy Thread
#4876
Heat will release the glue allowing the tires to peel off the rim.
#4878
Heat oven to 325-350 degrees. Place aluminum foil on cookie sheet. Set wheels down on foil, insert cookie sheet into oven. Leave them in the oven for 10-12 minutes. When removing the wheels/tires from the oven, take them outside. They will be "smoking hot" and it will smell like a drag strip in the kitchen. Let the tires cool down and the will come off the wheel with almost no effort at all.
watch, now youll get them off no problem. it was probably just me
#4879
Yes but For racing on an off road track you wouldnt use that gearing. And if you do it's prob. Not the wisest choice. Onroad is what that gearing is good for. My friend vision who used to be on the vorZa threads allot used like a 26 or 28t pinion on his vorZa onroad. That car screamed it was so fast , he had the elite mount.
#4880
It had to be something because when I baked my Vorza tires off, there was nothing to it. Tires came out of of the oven and they were seriously smoking hot. Several areas on the bead had already come loose from the wheel. By the time they were cool enough to touch with a bare hand, the tires almost fell off the rim. The old tires were easier coming off the rim than the new ones that went back on the rim. The heat releases the glue and makes the tire expand.
#4881
#4884
The mount will be for off-road purposes. If you use it for on road and expect to use a 28T, it may not go that big.
Are people going to use our mount for off-road or on-road?
If you can go 28T on-road, then why the need for GRID? Stock mount should work since it is not subjected to jumps and rough conditions.
#4889
What Kv motor are you gearing it for 21T.
#4890
Also, Jeff told me to go to Mr.Mya's for his home-made spacers to raise up the differential mounts and of course diff itself, but he did not seem to come here often anymore , so if anyone has a spare one, i'll buy it from you, too.
Mr.Mya, hello?!!!! Some business here for you
p.s., a bit mad that i already cut the stock receiver box which turned into a total :ugly:, elite mount does not require box mod ;(
