HPI Vorza Flux 1/8 E-Buggy Thread
#5626
I like the 112mm shocks...it feels more in-touch with the surface by allowing the wheels to travel further down to maintain contact with the terrain. But to take full advantage you will need to make some additional mods.
The axles will rub against the A-arms and the camber links will rub against the wheels if you try to get full extension of the 112's. So you will need to add the droop screws to lock maximum travel and get the camber links to clear the wheels...and also cut a little away from the a-arms to get the axles to clear as well. Pretty simple, but needed.
First pic shows the droop screw location on the left and the camber location that would rub at full extension as well as the axle clearance with the cutout.
The second pic shows the modified arm and a new arm with a red mark at the location to cut away.
#5627
I have 3 new BLS451's new in the box for a Heli that I never built. I seen a lot of people using Hitec coreless/titanium high end servos(7955TG), but in the heli world.. BLS Futaba or JR 8717's are the cream of the crop. I would think brushless would be great for a steering servo? How's the stock steering servo?
#5628
The axles will rub against the A-arms and the camber links will rub again the wheels if you try to get full extension of the 112's. So you will need to add the droop screws to lock maximum travel and get the camber links to clear the wheels...and also cut a little away from the a-arms to get the axles to clear as well. Pretty simple, but needed.
#5631
BEC
Isn't there an adjustable BEC output voltage through the Castle link?
#5635
Kit
What's a comparible kit? Ve8? Any other good ones that are real popular? I like the Vorza, but I'm not opposed to building my own kit.
#5636
I have a BLS451 new in the box. I've read that a lot of people using Hitec coreless/titanium high end servos(7955TG), but in the 50/90 sized heli world.. BLS Futaba or JR 8717's are the cream of the crop. I would think brushless would be great for a steering servo? How's the stock steering servo?
hope this helps
bb
#5638
No nitro!
The new thing with Heli's is "Flybarless". Uses 3 servos on the swash(CCPM) and usually they're rated roughly 170oz each on average. Due to the flybarless gyro.. It's good to have those three servos FAST too. Most are about .06 to .10 speed. Which is just about as fast as tail servos. Yea.. That's why I'm leaning towards the Vorza. I read the D8 is nitro but the Vorza was built around it, but only electric. I can't stand nitro so that's not an option. Read some things about the gear mesh and some broken/missing parts since these are put together at a factory. What's the definate things that should be double checked after opening this up from the box?
#5639
Finally done
I finally got the rest of the parts to finish my Tekno chassis kit. Every thing is new except for the motor. It's a 2200 and it had the short wires so I made up some extension wires, they don't look too good. When I have more time I might make up another set. It already has dirt on it but that's ok it's not a shelf qween.
The next pic is the pic paint job, I absolutly hate the look of the 8ight body and it didn't come with any kind of a nose cone. I need to find some kine of small nose cone, it would look better. I put on a DE bumper skid and one of their rear skids. Plus I couldn't stand the thought of getting that beautiful chassis scratched up so I put on a chassis protector.
The second pic is my quicky dog bone repair, if you ever lose a pin out of one of you bones just put a screw in with a locknut it'll get you going.
The last pic is for Ben!!! I should have zoomed in a bit. LOL
