HPI Vorza Flux 1/8 E-Buggy Thread
#7126
#7127
#7128
#7129
#7130
Suspended
Ok, so I'm wrapping up my spending spree on my vorza and I'd like to share what I have purchased. Maybe you guys can throw out some more that you would think I need to be fairly race competitive & have the duriblity there:
(Let me start out first by saying i'm not going with the Tekno Chassis at this time until I at least try out the stock one.)
1. RC Screwz kit (I know Tony's is better, but I threw it into a lump order wtih tower & it pushed me over the coupon threshhold )
2. ACE DS 1015 Digital Ultra torque servo ----
3. Tekno R/C M8 Driveshafts HB ----
4. Mugen R L suspension shaft w/nuts ----
5. Hot bodies aluminum steering horn #25 (I have a question about this)
6. Tekno RC Shock tower (D8B front 7075 Aluminum)
7. Robinson Racing 17T 5mm extra hardsteel pinion ----
8. Tekno RC Shock tower (D8B rear 112 mm Shocks wing mount) --- ( I have a question on this)
9. Hot Bodies big bore shock set - 112mm ----
10. HPI Racing Castle link programming kit ----
11. DE Racing BumpSkid (Hot Bodies D8) ----
12. M2C Racing 4mm Inner Front Captured Hinge Pins (2) ----
13. DE Racing XD "Extreme Duty" Rear Skid Plates (3) (Hot Bodies D8/D8T) ----
14. DE Racing Hot Bodies D8 Buggy Mud Guards ----
15. KYOIF148 - Kyosho 46T Spur Gear ----
16. HBSC8021 - Hot Bodies Differential Gaskets ----
17. LOSA17759 - Losi Pre-Mounted 1/8 Street On-Road Tires w/Yellow Wheels (2)
18. PTK-LPH-5000-2S65-W ProTek R/C 2S "Supreme Power" Li-Poly 65C Hard Case Battery Pack (7.4V/5000mAh) (ROAR Approved) ----
Aside from the charger that's about it. Any tools you guys think I could use? I have all Allens from .5mm to 3.0mm, but I don't have any screw drivers & phillips. The Savage had a lot of phillips & I hated it. I'm an allen only guy. I haven't had a chance to go through the vorza yet, but I'm assuming they are all Allen (from what I quickly observed).
Ok, so for my 2 questions:
1. The servo horn ---- is this the correct size horn to fit on my DS1015 servo? I initially purchased this horn to go on the stock servo, but I decided to replace it all together. The last DS1015 I had the horn stripped. Will the Hotbodies #25 one fit? If not, I'm just returning it.
2. The rear tower (Tekno) & wing stuff. I saw below some talk about it, I'm not sure what the issue is. Is there going to be a problem fitting the wing mount onto the Tekno tower?
So, aside from any tools I need //// The 2 questions I asked //// Do any of you see any further suggestions on parts I should get not what I already got?
Special thanks to Cain & Z for the jump start in the Vorza world (as well as others in past posts & other suggestions)
OH, AND I'M ALSO GETTING THAT ELITE MOUNT IF I SEE ONE OR IF ONE COMES IN STOCK!!! Lol.....
#7132
The stock wing doesn't work with the Tekno wing mount because the spacing on the holes that were already there. If you purchase a new wing and drill your own holes it will work.
On that note I'd like to recommend Jconceps Punisher wing, by far the best wing I've ever purchased. I use it on my Ve8 and Vorza. It's not just for the interchangeability of the side dams but also for its durability, you can tell its a much beefier wing. I changed to it because I was tired of the HB ones breaking in the vent area.
#7133
You can use the stock wing mount on the tekno tower.
If you want, you can use the tekno wing mount, it has a different mounting position. You could also use the losi wing mount with the tekno tower.
HB wings only work with stock mounts. Losi, mugen wings work with tekno mount. Proline, jconcepts, and other aftermarket non predrilled wing work with either mount.
The tekno mount has more adjustments than the stock one
#7134
have you had any luck on the elite rc website with the vorza motor mount?.I have been trying for weeks and weeks.I have never had any response from my emails neither.Shame really because i would really like one of these.If you get any response will you let us know?.......Thanks....
#7136
Suspended
You should pretty supportive of the punisher wing. Got a part #? Thanks
Hi there sarinexia,
You had to replace the hubs or the bearings? If the plastic hubs consistently break I'll go the aluminum, but they are so friggin expensive
#7137
Tech Legend
These should take care of any of the issues with the shafts falling out of the diff cups.
Good choice or the 44T works good too. remember to LIGHTLY sand the lip of the gear part that goes on the diff, NOT the diff (you'll see what I mean when it comes in)
For tools, you already have a set of allen drivers. if you don't however have a ball end 2.5mm allen driver, I would recommend that as those can be handy in the 2mm and 2.5mm size. A 17mm wrench for the wheel nuts that allows a hex driver to pass through the center of it can be helpful too.
A good set of nut drivers like the AE style ones work well especially if they have a thin wall to get into tight places.
Dentist pick works excellent for dirt removal.
For charger, love the Hyperion stuff. if you can find a used 606 Duo i think its called, excellent charger for the money. Get a power supply of at least 25 amps.
As for the rear hubs people have mentioned, me personally no issues. I want lightweight so I don't do the alloy stuff. For spares just buy stuff on ebay from parted out hara kits.
#7139
Suspended
I actually bought 4 of these . Amain was having a special on them so I just dropped the $240 or so bucks and got it out of the way. I'll be running (2) 2s lipo's in series.
All the tools you mentioned I have, --- even including a compressor I use to clean my cars.
Sounds like as far as the parts are concerned (with the exception of the punisher wing) I've got everything I need.
I was turned onto a "bullet proof" shell on Ebay. Watched a video of a Chevy Silverado run over it and the thing didn't have one crack. Just poped it back into shape. Very interesting. I think I'm going to buy one and give it a go.
