HPI Vorza Flux 1/8 E-Buggy Thread
#4861
So that diff oil set up is the best on track and to bash? I have the stick diff oils and bashing is great, but on track it's not so great. So 5,7,3 will be great? Do I need to order new gaskets? Also I don't have I think it's called napthane or something like that to clean out the diff oil, what else can I use that's a common household chemical that I can use to clean out the diff oil?
#4862
Suspended
Diff oil depends on what the buggy is doing; how it is reacting or not doing what you want it to is what determines what diff oil you should use.
Excellent article here:
http://users.telenet.be/elvo/
#4867
cleaning
Nothing special really. When it's this nasty I take out the two motor mount screws and the two that hold the esc down, unplug the esc from the receiver. That way I can lift the motor and esc out. Only reason I take the motor out is it's quick, plus makes it easy to clean the chassis in that area. Takes about two mins and then I hit it with a garden hose. Much easier than taking the whole buggy apart and cleaning each piece. The weather will be getting much better in a few weeks, then I'll completly strip it. Put in new bearings and do the difs at the same time.
#4869
I need your expertise... My vorza doesn't move freely anymore after I let go of the acceleration, sometimes it does and sometimes it doesn't. I checked my mesh and its good, when i move the buggy back and forth it moves good. Also there's a weird clicking noise that I hear, but I cant find where its coming from. Please any suggestions would help me out, thanks!
#4870
Sounds like it could be one of several things......
pin coming loose from a CVD
bad bearing causing drag
a diff gear may have chipped off and causing one of the diffs to lock
I would say pull the center diff and try to figure out if it is the front, center or rear section where the "drag" is coming from.
#4871
oh yeah, when the buggy is lifted up (not touching the ground) then the clicking noise is gone, but once its on the ground again I hear a clicking noise. I cant find it!! also I don't know why my buggy doesn't roll freely. Do you think its the bearings? My vorza is still new about 3 months old and I always went to clay tracks.
#4874
