SC10 Thread
Old 09-22-2011 | 02:15 PM
  #7246
Oso Negro's Avatar
Originally Posted by tazfam2
I am running it in a 17.5 boosted class will these gearings work in that class and what profiles thanks for the help
Sent you a PM
Oso Negro is offline
Old 09-22-2011 | 02:45 PM
  #7247
mxracer458's Avatar
i ran the tc spec boosted with a 17.5 and it was a slow turd.The profiles are tuned down for the mod motors.You need the sxx stock spec or tekin rs.Trust me,get one of those two speedos and you think you have a whole new car.I run at westcoast and you need everthing you can in a boosted sc.Im geared at 84/22 with the tekin rs
mxracer458 is offline
Old 09-22-2011 | 03:30 PM
  #7248
TeamNuts's Avatar
Default Ball diff issue
Okay, so I built and installed my new AE Ball diff but when I reassemble the truck, it seems like one of the dogbones is not long enough. It slides right out of the wheel hub.
Did I do something wrong?
Thanks!
TeamNuts is offline
Old 09-22-2011 | 04:59 PM
  #7249
Thanks!
Believe ball diff adjustment screw should be located on the same side as the slipper. Do not know if having it on the other side of the trans would make a difference.
Murray100 is offline
Old 09-22-2011 | 05:01 PM
  #7250
Thanks!
You will also want to confirm that the spring is in the deeper outdrive hole. Again, do not know if that will take care of your problem but something to check anyway.
Old 09-22-2011 | 05:07 PM
  #7251
Thanks!
This is a great you tube on how to build a ball diff. Hope it helps.
http://www.youtube.com/watch?v=AB7-q...840E96E89DD677
Old 09-22-2011 | 05:12 PM
  #7252
juzza99's Avatar
Do you guys run your battery more towards the rear of the tray or towards the front,
Cheers,
juzza99 is offline
Old 09-22-2011 | 05:42 PM
  #7253
20 SMOKE's Avatar
it depends on what you need,more traction move back,more steering move forward,i have mine in the middle
20 SMOKE is offline
Old 09-22-2011 | 06:41 PM
  #7254
TeamNuts's Avatar
I referred to that same video while building it. I figured the problem out - I didn't transfer the o-rings from the old gear diff to the new one...
Thanks for your help though!
TeamNuts is offline
Old 09-22-2011 | 07:38 PM
  #7255
Oso Negro's Avatar
+1!
Old 09-22-2011 | 08:22 PM
  #7256
CraigMBA's Avatar
That's not exactly right.
Moving the ballast back (in this case the battery) will cause the chassis to turn in harder because of more weight transfer, and the additional weight on the rear tires will give more grip on power.
Moving the ballast forward will give the chassis more steady state traction on the front end (like on a skid pad).
For reference, I have 3oz of ballast on the chassis between the trans and the battery, and the battery is about 3/4" back from the servo bulkhead. When the bite is good I have the fastest lap times at the track (I'm usually TQ), but when it gets slick after it dries out, my chassis is impossible to be aggressive with - in 17.5 and with no timing. Moving the battery further forward made things worse.
CraigMBA is offline
Old 09-22-2011 | 10:22 PM
  #7257
ilanstylz's Avatar
Need some help/tips everyone... Took my sc10 to the track today and I was having problems with keeping my rear end from sliding all over the place. I run on a hard packed tight clay track with a 13.5 motor and gold barcodes in the front and rear...... Should I try loosening up the ball diff, loosen the spur, add rear swaybar? Basically any help would be greatly appreciated so that my rear is more planted and not sliding all over the track like it has been and spinning out alot.........
ilanstylz is offline
Old 09-22-2011 | 11:48 PM
  #7258
CraigMBA's Avatar
What's your diff like?
CraigMBA is offline
Old 09-23-2011 | 03:22 AM
  #7259
eri3f0g's Avatar
Soften the rear springs?
Lower the rear ride height a bit?
put on .5 degree rear hubs.. That extra 1/2 degree of rear toe on top of the 3 degrees it has stock really changes things.
Do you have weight on the rear of chassis? if no, I'd throw 1 1/2 oz or so under rear shock tower behind battery... try it and check lap times, add more and try again, stop adding weight when laptimes slow down.
just .02cents.. try any and see if it helps.
edit: if that's the first time at that track.. don't assume those tires are what you need. Sometimes the easiest thing is to try different tire combo's as they REALLY make or break the truck regardless of setup.
eri3f0g is offline
Old 09-23-2011 | 05:36 AM
  #7260
ShortCourseOnly's Avatar
Originally Posted by t4mania
On a smooth track yes it will help..on a bumpy track it won't..
Adding the swaybar to the front will take away some steering..adding it to the rear will take away some rear traction..
Originally Posted by hotrodhomi
I haven't seen too many setup sheets that show a sway bar. Are people not using them? I run on a smooth indoor track, would the sway bars be helpful. They really helped my 4x4's
I have run the rear sway bar on smooth and rough tracks. What you need to do is define what you need to improve you vehicle's handling. If the smooth track has a lot of traction and you have all the rear bite you need then you can add the rear sway bar to increase steering traction. On carpet this makes a lot of sense. The effect can be done with springs and shock oil as well so that is why most set-up sheets do not use the sway bar. I took mine off over a year ago.
ShortCourseOnly is offline
