SC10 Thread
#4651
[QUOTE=rcannon409;7758761]
cheeeers bro , its turned out pretty good and i bash it all the time it ant no shelf queen . . just trying to think of more stuff to make for it , but im running out of ideas . lol im running out of projects , might need to sell sum thing and buy another car. dunno .
hi guys got bored today so made a front tower in carbon to go with the rest of the race truck . slowly i will have more and more stuff made out of it , next will be the rear when i got time , sooo what ya guys think ?????
I think that truck is beautiful. Pretty enough to hang over the fireplace. I wish I had the talent and skill to build something like it.
#4655
From: Norwood, OH...and CCRCR and The OhioRCFactory
If you're stripping out idlers you've got a whole 'nuther set of issues there, feller. Probably a toasted transmission bearing or you're just landing on the throttle WAY too much (which the 2nd one isn't likely, because that's how ThunderbirdJunkie rolls, and aside from having to fix the too-thin-shim issue in the diff he's had zero transmission issues)
#4657
The idler only stripped because I had the spring tightened all the way down. I got frustrated and just cranked it down. I took it around the track and it finally felt like it was putting the power down. But after a few jumps, the idler stripped out. I guess it is the weak link when you have no clutch to slip. Since then, I have just been tightening it a bit at a time.
I've heard two things from local guys. 1. Crank it down and back out 2 turns and adjust from there. 2. Tighten it till 2 threads are showing just like wild cherry said.
Still slips more than I would like it to. Others have suggested to replace the pads or sand them. I think I am going to try to upgrade to the v2 slipper.
#4658
On my B-4 ? I'm running the slipper even looser,
nut flush with the shaft .
Almost every racer I run into is running their slipper way to tight .
Even guyz that have experience....
#4660
Anyone running the RC8TE Big Bore shocks on their SC10? If someone has pics, please post.
What type of surface do you run them on? I currently have Team Losi XXX-T shocks on my car. I run my SC on asphalt and dirt. Was gonna keep the XXX-T shocks for asphalt and use big bore for dirt.
Chi
Chi
#4662
Chi
Chi
#4664
#4665
I'm sailing my sc10, almost ready to run if someone interested...
http://www.rctech.net/forum/r-c-item...eat-price.html
