Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
Hey guys here is an update to the project I have been working on. DEX410 with 3 DIFFS! Here are some specs and pics for your viewing pleasure!
7075-T6 +8 chassis
Modular design to run DESC410 center diff or stock 410 buggy slipper
Saddle packs or shorty across the rear.
Just need to finish installing the electrics and take it out for a test drive....
7075-T6 +8 chassis
7075-T6 +8 chassis
7075-T6 +8 chassis
Nice work B Man. I'll be interested to hear the track report.
So I picked up some of the 21* blocks and they are shorter than the plastic ones. Is there extra parts or washers that he with them? Can someone explain to me or show me a pic of them. I also picked up the front and rear alum shock standoffs. Anyone know the parts to put the shock caps on? I have the rv3 with small bore shocks.
R/C Tech Elite Member
The spacers or washers are 1mm top and bottom. Shock bushing are "D" type # TD330036
Guys another update. Just installed the electronics. Please don't be harsh the wiring is only temporary. I need to order some pigtails and fit the body. First thoughts/opinion. I think this thing is going to be sick. Took it for a quick spin in the driveway. I could get on it and brake hard with no loss of control, I even bumped the current limiter up, which is a no no for me. Very stable. Next is some on track testing......
Sweet. Is that a Tamaya body?
I am a bit lazy, so I just copied from the manual, with the shoulder spacers (340004) you shouldn't be able to over tighten with the 1mm spacers.
Attachment 1137513
Attachment 1137513
I'll have to do some playing with it. I was happy with the buggy for the most part. Deff don't care the battery remaoval. The rear diff loop fell off in the middle of my first heat leaving me with fwd so I pulled off. Do t like how the exotek is a slide on part I would much rather a whole peice. Running a 10.5 and a 24th pinion in the main I hit about 165*. But stripped the grub screw on the pinion so that's another issue lol.
When I tightend the wheels all the way down they wanted to bind up. I'm guessing alum wheel hexes will fix that? And there seemed like there was Grinding I still haven't figured out. Guess that happens when you buy used
Check if your buggy has the crush spacers installed in the hubs, not having them is the main cause of binding when tightening the wheel nut.
