Like Tree22Likes
Old 07-16-2011, 11:46 PM
  #6931
hmm, so for someone debating which kit to buy and build, the 410 at 399 cdn sounds like a pretty good deal.. I'm not competitive enough to well, compete yet, so this would be a decent car to buy.
would you agree?
I don't think my skill are good enough that I'd be able to take advantage of the "new" v3's features.
what do you think? tossup between this and the AE RC10T4.1.. totally different cars/class too.
what motor/esc combo would you recommend?
Edit: motor/esc I'll just do a search, probably go with some Tekin stuff as I hear they're fairly strong.
Feijai is offline
Old 07-17-2011, 07:15 AM
  #6932
bronc4now's Avatar
Trader Rating: 43 (100%+)
Originally Posted by t0p_sh0tta
If you're using the metal brace you must also use the alloy pivot balls.
Wow I shreached and found my answer 1st shot ,thanks I can't believe its not in the manual .are these parts in the kit I'm away right know so I can't look
bronc4now is offline
Old 07-17-2011, 07:26 AM
  #6933
tobamiester's Avatar
Trader Rating: 360 (100%+)
If your upgrading your 410R to metal braces, you need to purchase the pivot balls (I didn't know either and had to order them after the fact....)
tobamiester is offline
Old 07-17-2011, 07:52 AM
  #6934
bronc4now's Avatar
Thanks add that to my next order ..well looks like paint time !
Old 07-17-2011, 02:41 PM
  #6935
So what are the major differences between the 410 and 410r? Do you guys believe it is worth the extra $ to get the 410.
Thanks,
Beau
THE GOOCH is offline
Old 07-17-2011, 03:08 PM
  #6936
ABBOTT's Avatar
The diffs can be found on their site. Im perfectly happy with my R but u will have to put some extras into it. The front arm holder and balls being the only mandatory purchase besides new orings for the diffs. DO NOT EVEN BUILD A 410R WITHOUT THESE THREE ITEMS! For those that are going to ask the diff inserts are next on the list with ballcups and studs coming after that.You will save money on going with the higher end kit. However, it still has things that need to be updated.
Im hard on cars and this things is tough, but like anything else it can be broken with some effort.
ABBOTT is offline
Old 07-17-2011, 05:42 PM
  #6937
Jpm1's Avatar
Got mine built and love it, I went with box setup and it was good except for corner exit where you had to be very gentle or the ass would come around, I'm thinking thicker oil in the front???, also is there a direct replacement for the rodends???
Jpm1 is offline
Old 07-17-2011, 06:02 PM
  #6938
ABBOTT's Avatar
Tc5 Studs and any end you that fits I use the losi HD cups. No direct fit out there!
ABBOTT is offline
Old 07-17-2011, 06:03 PM
  #6939
ABBOTT's Avatar
Running any wieght? Try the Tresrey 30 gram insert.
ABBOTT is offline
Old 07-17-2011, 06:53 PM
  #6940
Matt Howard's Avatar
RPM 73360 super duty rod ends are a direct fit to replace the crap rodends.
Matt Howard is offline
Old 07-17-2011, 06:56 PM
  #6941
Konich's Avatar
I think Durango is coming out with white HD ballcups.
Konich is offline
Old 07-18-2011, 03:20 AM
  #6942
Question, the 310039 part that connects to the Lipo holder on DEX410R, and threads over and into the rear gearbox, you got two holes on it for the battery pin to go through, which one should you use? The upper or the lower one? Or does it depend on how big batteries you have? Mine are 25mm in height.
Its on page 27 in the manual.
Nitrius is offline
Old 07-18-2011, 03:30 AM
  #6943
Jpm1's Avatar
no im not running rear weight, im running 5100mah batteries though which are weighty, ive just changed setup to randy pike setup except oils (no time so far), i do like the way the buggy jumps though so i imagine the weight would make it back heavy???
Jpm1 is offline
Old 07-18-2011, 03:44 AM
  #6944
use the upper one if your batteries are 25mm
Old 07-18-2011, 03:52 AM
  #6945
Yea, just tried, and noticed that i had to use the upper one, hehe. Thanks
Nitrius is offline
