Like Tree22Likes
Old 11-19-2013, 11:38 AM
  #14416
the incubus's Avatar
Trader Rating: 17 (100%+)
Originally Posted by jmackani
I installed the 21 degree blocks and to be honest if you have a radio with dual rate adjustment, then you can probably save yourself some money. The same effect can be accomplished by dialing out some of your steering. I ran without the 21 degree blocks for almost two years and decided to try them. They basically just calmed the steering which can essentially be accomplished with dual rate on your radio also.
I tried that and it calmed it down a bit, but the affect of the Blocks changes how the entire car corners and allows the front wheels to bite as you apply the power, thus preventing the rear from whipping around on you. Overall it makes the car not only easier to drive but makes it robustly consistent in regards to reaction from steering input. With out them some input can make it dart off considerably more abruptly.
I'm not very good anymore these days thanks to a 20+ year layoff and was struggling quite a bit and these blocks took 2 seconds off my times easily as I jumped from 29-31 second laps to 27's consistently and have dropped down to the 26's and on the verge of the ever illusive 25's!
[kneels down and prays]
the incubus is offline
Old 11-19-2013, 01:49 PM
  #14417
huzzler's Avatar
Wow! 2 seconds,it sounds like those blocks really helped you out. Might have to give them a shot. You know they will change track layout before you get that 25 second lap. Always happens to me
huzzler is offline
Old 11-19-2013, 02:49 PM
  #14418
2 seconds for sure!
Overall when you find yourself over correcting constantly you lose little bunches of time that amount to more than we think. When a car is dialed and you are running the proper rubber, the car drives almost like a slot cat so you just have to manage how much throttle to give and it goes. I'm now receiving a bit of advice from a local pro who runs the 44.2 and he is bestowing me with his wisdom on tires, shock and diff oils and overall setup. I've gotten this far on my own so I'm fully expecting his input to get me to that damn 25 second lap! LOL
Old 11-19-2013, 04:12 PM
  #14419
What are you guys using to prevent the pin in rear-center driveshaft from coming out? I've heard that it can happen and then ruin the battery pack. Is there anything apart from shrink tube? For example something similar to the plastic cover that is used in xb4.
Donat is offline
Old 11-19-2013, 04:34 PM
  #14420
ekt
ekt's Avatar
The kit does come with a small plastic collar to put on the driveshafts, it's with the gearbox pieces. Another option is using some axle boots as shown in TDs CVD build guide http://www.team-durango.com/blog/200...ing-your-cvds/
ekt is offline
Old 11-19-2013, 05:39 PM
  #14421
jmackani's Avatar
Trader Rating: 14 (100%+)
Some guys are using the cv boots on the centers also. I would just wait a month and buy the u joints and never worry again.
jmackani is offline
Old 11-19-2013, 05:53 PM
  #14422
8ight-e's Avatar
Trader Rating: 58 (100%+)
It comes with a plastic retainer.. I've never had a retainer fail in 2yrs. That and thread lock the grub screw good.
8ight-e is offline
Old 11-20-2013, 12:10 PM
  #14423
Thanks! I didn't notice that part!
Donat is offline
Old 11-20-2013, 12:16 PM
  #14424
I had this issue earlier this year and nothing helped except red loctite. The plastic collar wouldn't hold, the shrink wrap out get punched thru and it ruined a batter for me. I used red loctite and haven't had to think about it since.
TLRrunner is offline
Old 11-20-2013, 07:15 PM
  #14425
Default Anti squat
What is a good starting point for smooth indoor type track on anti squat??
Iggy 102 is offline
Old 11-20-2013, 09:18 PM
  #14426
8ight-e's Avatar
upside down 1's, if the jump faces get bad make them right side up
8ight-e is offline
Old 11-22-2013, 05:23 PM
  #14427
fifi's Avatar
view of the new front arm
http://www.team-durango.com/part-inf...artNo=TD230037
fifi is offline
Old 11-23-2013, 03:09 PM
  #14428
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Hey guys here is an update to the project I have been working on. DEX410 with 3 DIFFS! Here are some specs and pics for your viewing pleasure!
7075-T6 +8 chassis
Modular design to run DESC410 center diff or stock 410 buggy slipper
Saddle packs or shorty across the rear.
Just need to finish installing the electrics and take it out for a test drive....
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-4103d.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-4103d1.jpeg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-4103d2.jpeg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-4103d3.jpeg
Bman's 3XNT is offline
Old 11-23-2013, 07:01 PM
  #14429
R/C Tech Elite Member
Trader Rating: 520 (100%+)
7075-T6 +8 chassis
Wow, very spacious...
flame56mx is offline
Old 11-23-2013, 07:45 PM
  #14430
CarlCrocco's Avatar
Trader Rating: 92 (100%+)
7075-T6 +8 chassis
Looks amazing, where do I send my money?
CarlCrocco is offline
