Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
That is the slipper slipping. For sure. Maybe go a half turn on the nut or replace the pads. I had to lock mine down completely when I was using the 4 pole to keep it from slipping, even with new pads(turf). Just left it that way which is fine on turf, but sometimes I do lose the spur, which leads to the following scenario...
Anyone else ever gotten a bad machined spur gear?
My molded one let go and all we had on wall was a machined version. Put it in and the slipper assembly wouldn't go in the mount. This made me think maybe the mount bent and that was what caused the spur to let go in the first place.
Tried putting that same assembly into a buddy's car and it was the same, which made me think maybe the slipper assembly was bad(bent outdrive or something)
So I pulled it apart and gave the spur to that same guy, and he assembled it with his parts, and it did the exact same thing in his car, with his parts.
So it has to be the spur right?
Anyone else seen this?
If aluminum bulkheads were offered for the 410 who would want it and how much would you pay for it?
I'd consider one if the weight did not increase. I think $20 would be about right. STRC bulkheads for the RB series are $20 and they are quality components. I was told to stick with genuine Kyosho suspension hangers because the quality of STRC hangers was inferior. Being as I had the option to exchange if I found that to be the case, I went with the STRC ones and they are every bit identical to the Kyosho hangers and the fit is identically precise.
Matching Pewter ano would also be ideal. It sucks having different colors on components throughout a car.
$20 per pair or per side? I'd be willing to pay for a full set both fronts and the rears. I've sent an email to Exotek and posted a message on the Tresrey thread to see if there was a demand if they would look into it. To avoid weight increase they would probably have to be machined which would add to the cost I assume over a stamped piece but I'm not a machinist so I dunno. Hoping to hear back from them with some good news.
I'm personally not too concerned with color, black works great for me you can't see all the color pieces half the time anyway.
Well, I tries the 50 durometer Tamiya xrings with no luck : (
They felt really smooth when I built them up - maybe too smooth : /
Ran the car the first time with them and all four shocks leaked really bad. Taking off the caps, one had oil to about 3mm from the top, two were about 1/2 full, one was completely empty! Was I supposed to green slime them first? I built them up and the car sat for 4-5 days, so the oil in there should have swelled them up? idk
Before taking them apart, the shafts had a lot of play back and forth. The rings are definitely much looser on the shaft.
I rechecked the part number - got that right. Losi oil. Maybe I really DID need to use mineral spirits based oil. But you didn't, right?
Back to stock orings for this week.
Mark
I'd like to see a set (front and back) priced around $35. The problem with Tresrey is that they will be RED. I'd have no issue with Black either but the Pewter will match all the Durango components like the front blocks just fine.
Ill try tightening up the slipper and see if the noise goes away. Thanks for the advice, my slippers are made by rcshox out of same crazy material. They dont burn out lol
Hey guys, on alot of the setups on petitrc I see 2 and 3 hole pistons. Are guys drilling their own from the blanks you get??? I only see four hole on the Durango site. Could someone shead some light on this for me.
Also shock piston kit that will be coming our way new is TD330590 and contains
2 x 1.6mm - 1 pair supplied
2 x 1.7mm - 1 pair supplied
3 x 1.6mm - 1 pair supplied
3 x 1.7mm - 1 pair supplied
I'll get some stock spurs on the way. Thanks man.
Super glue tooth picks in the hole, cut, then make a little glue top on each side to keep it in place. Drill holes to the larger size if needed.
R/C Tech Elite Member
anytime you hear squeaking noise you need to grease your center drive shift coupling,
