Like Tree22Likes
Old 05-19-2014, 11:12 AM
  #15886
racingdan's Avatar
Default My DEX410v3.5
I custom made this winter my 410v3.5 with center diff, take a spare diff with some mod on a traxxas stampede spur ,it run very well on slippery track and also on hi traction dirt track
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-file0021-copier-.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-file0020-copier-.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-file0022-copier-.jpg
racingdan is offline
Old 05-19-2014, 11:19 AM
  #15887
kufman's Avatar
How is the balance? Looks like a lot of weight in the back of the car.
kufman is offline
Old 05-19-2014, 11:36 AM
  #15888
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Wow, that looks great! What weight oil in the center diff? I am currently running 100k and loving it. Nice work...
Bman's 3XNT is offline
Old 05-19-2014, 11:56 AM
  #15889
racingdan's Avatar
the balance is very good, have lot of steering and the rear end feel vrey good,my diff oil are 5000f,7000c and 2000r and can run fastest lap versus my other 410v3
Old 05-19-2014, 05:43 PM
  #15890
RC10Nick's Avatar
Is that a dex410 diff you used? After seeing your post I checked the length of the f/r diff to the length of the slipper unit and they matched! Holy cow, how did I not see that before?
Can you post some more info on what spur you used and how you modified it?
RC10Nick is offline
Old 05-20-2014, 12:03 PM
  #15891
13Maschine's Avatar
I broke a lot of suspension arms last Sunday while racing and while I did take some really good tumbles and crashes I wonder what the rest of us have done to strengthen the arms? boiling them?
I wasn't the only 4 wheeler who had trouble finishing the races either. it was a pretty hot at an indoor track.
I love my Durangos especially the 410 narrow design. But….Forgive me but I think I want a D413 for the strength of the design and easy swap between battery types….
13Maschine is offline
Old 05-20-2014, 12:14 PM
  #15892
lighten the car, get he car under 1750g and it's pretty much indestructible.
Mine is about 1725g, seen some very nasty crashes, and haven't broken anything in about 4 months now.
nicholasxuu is offline
Old 05-20-2014, 12:39 PM
  #15893
13Maschine's Avatar
Hmmm, That makes sense. Obviously the answer is also don't crash!
What kind of lightening have you done? Titanium screws? I have the carbon fibre towers. I'm running the tresrey titanium hinge pins. Which I must say rock, they survived all the arm snapping crashes and seem to be perfect still. I need to roll them to check but every new arm I put on didn't bind at all. Can't say that for my lunsford pins.
Has anyone noticed the new V4 drivetrain parts being lighter? like the Ujoints and such? Seems like they would be similar and the double joints being maybe a bit heavier?
Old 05-20-2014, 02:13 PM
  #15894
cheaper way would be:
not to use aluminum upgrade unless necessary. (ha, TD must hate me now)
remove those bass weights if you put on any.
use shorty lipo if your race is not that long. -60~100g
use low profile servo if you can. -20g
even chassis protector weights about 10~15g.
Those 12AWG wire can get heavy as well, try make them shorter.
*I haven't put on anything titanium yet.
Old 05-20-2014, 05:26 PM
  #15895
13Maschine's Avatar
Shorty pack doesn't fit normally and requires modifications. This also makes the rear end super light over the front end unless you move the motor around. I think the car would be overly unbalanced this way unless you add weights then what's the point. If you don't run the rear 30gram weight the car is pretty forward biased already.
Which low profile servo do you use? Seems like many of them don't have the torque or speed for a wheeler.
Old 05-20-2014, 05:39 PM
  #15896
1. shorty require very little modification. for me, minimal trim on rear bulkhead, removed battery mounting area on rear hoop (cheap plastic one, got a few in spares anyway), the most work I got is drilling two holes on the chassis to mount shorty. Though it seems some batches of chassis has those holes pre-drilled.
OH, and my car have 49.5:50.5 F/R weight distribution.
2. normal low profile like savox 1251 is good enough for wheeler. especially after the light weight work.
I'm using the cheap solar d770 servo right now, slightly longer and a couple gram heavier than regular low profile servo, but work just fine, and really really cheap.
*I know friends using low profile on their much heavier 22-4, all fine.
*we run on pretty high traction clay, servo performance does matters theoretically, low profile is fine.
Old 05-20-2014, 06:14 PM
  #15897
13Maschine's Avatar
Can you post pics of your shorty setup?
  #15898
13Maschine's Avatar
Thanks for your tips btw
Old 05-20-2014, 06:40 PM
  #15899
racingdan's Avatar
yes it`s a 410 diff with machined gear to help on centering the traxxas stampede 86t spur
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-file0024-copier-.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-file0026-copier-.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-file0027-copier-.jpg
Old 05-20-2014, 06:53 PM
  #15900
you could have waited and use the new Team C center diff for buggy.
