Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
i have to stay around 17-19 mostly 18 because of you run out of room for adjustment on 17
but i actually went up to a 93 spur so i can have more adjustment area...
Thinking to sell my DEX410R Roller as I just think I will be using it, it has very very little use in it.
Sean
Sean
Thank you everyone for the answers. Looks like I need to buy a few pinons.
body help
as far as the electronics go this is a very tight fit, had to mount my rx on its edge to fit the ESC (Havoc Pro)...
what is a good body option that will allow some extra room for the wires and capacitor on the Havoc Pro to fit?
ok guys
I got a new set of big bores on the way
any setups for high traction indoor clay running saddles
what about new tapered pistons?
you can also consider the losi HD ballcups. inexpensive upgrade. 1 of my cars came with the losi ballcups from the previous owner. after 18 mths, the ballcup had popped out once only.
http://www.losipartshouse.com/servle...id-Ball/Detail
also .. personally, i think the turnbuckles are strong and beefy. no need for Ti or Lunsford upgrades. the $$ is better spent elsewhere . but the $$ is yours not mine
R/C Tech Elite Member
I use the stock body but here is how I mounted my Havoc Pro and other electronics.
Where are most of you guys starting at on set up?
Hi,
i've got a question about the TD TWO WAY SLIPPER SET / Part No: TD210008, did someone hear or read about it?
Is there a need for some special tracks, or what do u think about it?
I heard about it, no pics anywhere?
