Like Tree22Likes
Old 09-06-2012, 06:43 AM
  #11011
Originally Posted by slow_jun
Drive shaft boots are not included, but the drive cup caps are, just buy them, they are effective way to keep the dirt out the cups and joints.
better using the shrink tubing, effective way to keep the pins where they are suppose to be.
Thanks for the help, i have ordered the shaft boots too!
Witch one do you mean with the "drive cup caps"? Sorry, i dont understand that!? (my english is not the best!)
Do you have a part#?
micholix is offline
Old 09-06-2012, 09:38 AM
  #11012
slow_jun's Avatar
Trader Rating: 14 (94%+)
The outdrive has a plastic cup cap that you need to insert,thats were the boots slides in. Dont have the partnumber but if you search for the dex410 2010 specs,you will get it( also 410 v1 manual).
slow_jun is offline
Old 09-06-2012, 09:56 AM
  #11013
Yes, i found it, it's in the gearbox set! Thx
Bought a new lipo and a rcscrews stainless steel screw kit at a shop close to my home, now i just need the car to start!
micholix is offline
Old 09-06-2012, 05:50 PM
  #11014
tekin rs with 8.5 ... it is enough torque/speed for him? Im thinking about wich one kit will be the better for me,,,
privategab is offline
Old 09-06-2012, 06:52 PM
  #11015
tobamiester's Avatar
Trader Rating: 360 (100%+)
Your going to need an RS Pro. In general an RS will run too hot in this vehicle.
tobamiester is offline
  #11016
gene1219's Avatar
Trader Rating: 16 (100%+)
Originally Posted by qwkpony
Pic of the latest (hopefully last) electronics install on the 410. I challenge you to get a cleaner layout.
I see your electronics install and I raise you with:
gene1219 is offline
Old 09-06-2012, 08:00 PM
  #11017
jmackani's Avatar
Trader Rating: 14 (100%+)
I ran all last season with an rs and a 7.5 in my 410 and never had a single heat issue. In addition, I just ordered two new rs's from tekin directly and invoice shows a 5 turn limit on them.
jmackani is offline
Old 09-06-2012, 08:15 PM
  #11018
Ok dokay then, I stand corrected. Personally I wouldn't use an RS in a 4WD Buggy, regardless of motor wind. But thats just me.
Old 09-06-2012, 08:26 PM
  #11019
Trader Rating: 78 (98%+)
I'm with you Toby... Speed Passion FTW .
Raul Garcia is offline
Old 09-06-2012, 09:37 PM
  #11020
My 2010 spec got run over by a bus, but some things such as the titanium turnbuckles and a few miscellaneous parts survived.. what would be some essential upgrades with the V3 I should get? Probably gonna get the TD aluminum rear bulkhead braces, but other than that?
I have the Tresrey hoops and some of the bearings from the 2010 car. Which of the rear hub carriers should I get, they have 1' and 0' ones.
Thanks..
jjjheimer is offline
Old 09-06-2012, 10:49 PM
  #11021
Trader Rating: 19 (100%+)
Gene- you're going to want the aluminum side pods to go with that CF chassis- without them there is too much flex and potentially a cracked chassis in your future. Cush has two full seasons on a Tresrey CF chassis and he absolutely loves it, and no issues at all with durability running the aluminum sides.
Jonny5 is offline
Old 09-07-2012, 04:27 AM
  #11022
Briguy's Avatar
Trader Rating: 125 (100%+)
It can be done with a RS if you have your ESC setup and gearing dead on correct . I have seen a lot racers burn up their ESCs though and surely wouldn't be recommending to use a RS .
FYI , due to today's batteries and motors Tekin changed the motor limit of a RS to 7.5 .
Briguy is offline
Old 09-07-2012, 08:00 AM
  #11023
Trader Rating: 38 (100%+)
Anyone interested in buying the D-Joint center drive shafts? New in package for $45 shipped. PM me
jzwolen is offline
Old 09-07-2012, 09:43 AM
  #11024
gene1219's Avatar
It's actually just a vinyl decal. I purchased it from autozone. It's really nice since there is a woven texture to it. That's how I ball on a budget
gene1219 is offline
Old 09-07-2012, 12:38 PM
  #11025
JosephBlack's Avatar
Thanks..
Sorry to hear about the bus. You need nothing for the V3 in addition to what you already have. Buy it and race it.
JosephBlack is offline
