Like Tree22Likes
Old 01-17-2013, 04:50 PM
  #11911
Trader Rating: 25 (100%+)
I got my kit used and it has a bunch of rear hub spares but it seems the outer pin does not fit in the hole. The hole is a little bit smaller. Would it be ok to drill them out to fit the pin or should i get some new ones?
chevmaro is offline
Old 01-17-2013, 06:54 PM
  #11912
dangerwr's Avatar
Interesting. I would use a reamer but understand they may not be available in that size. Personally I would sneak up on it with a drill. Does it fit through the hub??
dangerwr is offline
Old 01-17-2013, 07:01 PM
  #11913
They fit fine we're exact same in every way except the outer pin hole. I found a crew the same size as the pin and threaded it in there got them to work.
chevmaro is offline
Old 01-17-2013, 08:44 PM
  #11914
dangerwr's Avatar
The only thing left to do is give it hell. Seriously, rip its head off.
dangerwr is offline
Old 01-17-2013, 08:45 PM
  #11915
hotdognobun's Avatar
Trader Rating: 32 (100%+)
hotdognobun is offline
Old 01-17-2013, 08:51 PM
  #11916
morris's Avatar
Trader Rating: 44 (100%+)
out of curiousity...now that i have my 210 pretty close..i am starting to work on my 410.i normally run the same pistons in both my cars.so in my 210 im running 6 hole 1.4 and i like that setup so far..i did the same in my 4 wheel and it feels way to soft....(will chassi slap very easily)
what are alot of you guys running piston/oils/springs?
morris is offline
Old 01-17-2013, 09:01 PM
  #11917
8ight-e's Avatar
Trader Rating: 58 (100%+)
Well had my first taste with the 410 at our new local indoor clay track (redneck raceway), FUN! This class is just starting at our track we had 3 of 7 buggies going (4 for main) for next week and hoping for about 12 total racers as points start up. For this practice night we are just tuning.. I must say I don't need to change much.. just need to hold my lines.
http://www.ustream.tv/channel/modsqu...orded/28553740
pretty high bite clay track..
8ight-e is offline
Old 01-17-2013, 09:09 PM
  #11918
R/C Tech Elite Member
Trader Rating: 520 (100%+)
I am running 1.6x2 frt, and 1.7x2 rear with 35wt in all four..
flame56mx is offline
Old 01-17-2013, 09:14 PM
  #11919
morris's Avatar
ok thx for the info..are you running the stock durango pistons?or are you running a different kind of pistons?
morris is offline
Old 01-17-2013, 09:18 PM
  #11920
Stock ones, you can use the blanks that come with the kit, or I usually plug with Ca and toothpick, and drill the unplugged holes to size..
Old 01-17-2013, 09:22 PM
  #11921
symmetricon's Avatar
Trader Rating: 27 (100%+)
If you are running 6 hole 1.4 in your 210, your track must be pretty loose and bumpy, much like mine. My 210 is dialed at my track, but am working on my 410. Im currently using 2hole 1.7mm front and 3hole 1.75mm rear. Still playing with oils, I suspect if your track is like what i think, 2hole 1.7 in the rear will be pretty stiff and overpack through the rough stuff.....
symmetricon is offline
Old 01-17-2013, 09:44 PM
  #11922
Woulvesbaine's Avatar
Originally Posted by ekt
I cannot remember which car I ran bladders in but I remember I liked them for their simplicity. You fill to the top and just put the bladders in and you're basically done. Maybe it was an eight scale.
Woulvesbaine is offline
Old 01-17-2013, 10:18 PM
  #11923
Boadazofa's Avatar
Trader Rating: 33 (100%+)
Anyone got the part number for the 10mm bladders for the dex410 2010 spec? Cant seem to find them on the tsr website!
Boadazofa is offline
Old 01-17-2013, 10:20 PM
  #11924
http://www.tsrproducts.com/index.php/pit-gear-1.html
i tried them all and blue with med foam felt great
Old 01-17-2013, 10:25 PM
  #11925
here
