Like Tree22Likes
Old 10-02-2012, 04:26 PM
  #11131
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by air8
Quick question. Why are the Aluminum diff hoops needed?
They're not essential, but almost essential, moreso the Rear. I've only toasted one front in the 2 years I've had a DEX. But had a few rears fail which has ended my raceday...
tobamiester is offline
Old 10-02-2012, 06:33 PM
  #11132
Originally Posted by INFERN0
You should try the plastic side rails and the rear flex brace to give the car a bit of flex. Without knowing what was handling characteristic of car it's tough to say where to start. Try a few online set ups from Lutz using similar surface type as a starting point.
One thing I noticed is this car handles very well but it doesn't suit everyone's driving style.
I have mine set up so it pivots corners easy, slight push out of corners under power but then I never blip my throttle or punch it out of corners. I drive it very linear like a 1/12 pan car. Others that drive my car say it oversteers and they can't get used to it..
Try some set ups as reference points and each time out make only one adjustment as this car reacts to changes easily.
Thanks for the reply. I've ordered the plastic side rails and the flex brace. I really think the problem is the lack of flex. I race a B44.1 at all the big races and really like it but I hate ball diffs.
CTEKTOOL is offline
Old 10-02-2012, 08:34 PM
  #11133
EvanAZ's Avatar
Trader Rating: 99 (100%+)
Looks like I am getting one this weekend.
Plan on running an Orion 6.5 with a Havoc Pro, any good starting points on pinion size?
EvanAZ is offline
Old 10-02-2012, 11:06 PM
  #11134
itr
itr's Avatar
Hey Even i currently have a trinity 6.5 and havoc pro in the car right now and have it geared at 87/18 and the car is a bullet almost too much at times lol
itr is offline
Old 10-03-2012, 12:26 AM
  #11135
Jochim_18's Avatar
Finally figure out my buggy it was on the rail tonight and broke the track record.. I got the DEX410R V3 regular shocks makes the car really Bouncy so it's time to upgrade to big bore.. Plastic side rails really help to haven chassis flex..
Jochim_18 is offline
Old 10-03-2012, 07:33 AM
  #11136
dexon555's Avatar
On tracks with huge, high-energy jumps, the rear alloy diff hoop is necessary. If you land nose hard off a huge jump the chassis flexes foreward like a "U" and the plastic rear diff hoop can break.
That being said, it's just one of those "added insurance" parts...it's better to have it and not need it than to need it and not have it. IMO
dexon555 is offline
Old 10-03-2012, 07:37 AM
  #11137
boudin4evr's Avatar
Trader Rating: 18 (100%+)
what are the part numbers for the big bore conversion?
what pistons are people running in them?
I have the R car with all the aluminum mods and CF flex brace and CF shock towers
boudin4evr is offline
Old 10-03-2012, 09:18 AM
  #11138
itr
itr's Avatar
what is the advantage of the rear aluminum diff inserts
itr is offline
Old 10-03-2012, 10:05 AM
  #11139
t8rtot's Avatar
Trader Rating: 14 (94%+)
Strength, some have issues, mostly casing jumps.. I never had issues
t8rtot is offline
Old 10-03-2012, 10:20 AM
  #11140
itr
itr's Avatar
so i should be ok with the plastic ones in the 410 buggy and 410 sc
itr is offline
Old 10-03-2012, 10:31 AM
  #11141
+1 Me neither. Actually I added them in a moment of excessive shopping for hopups..and broke the rear bulk head. Been running plastics ever since, no issues. Save yourself $40 and put it into some nice Ceramic bearings or other hopups.
Old 10-03-2012, 11:13 AM
  #11142
Trader Rating: 38 (100%+)
i've broken the rear bulkheads using the plastic diff inserts as well
jzwolen is offline
Old 10-03-2012, 11:50 AM
  #11143
Briguy's Avatar
Trader Rating: 125 (100%+)
The standard shocks don`t make the car bouncy , your shock setup makes them bouncy .
Briguy is offline
Old 10-03-2012, 12:06 PM
  #11144
itr
itr's Avatar
cool thanks for the input guys
itr is offline
Old 10-03-2012, 02:57 PM
  #11145
Trader Rating: 44 (100%+)
i believe the big bores set are below but hope someone could help confirm them.
1/10 ELECTRIC BIG BORE SHOCK SET: 23MM STROKE TD230004
1/10 ELECTRIC BIG BORE SHOCK SET: 31MM STROKE TD230005
wyl03 is offline
