Like Tree22Likes
Old 04-24-2013, 09:22 AM
  #12661
Originally Posted by tobamiester
Yes, or a close configuration. I ran the VTX10RBE with VST 7.5. Ran very well and pretty cool. Mess around with the Punch and Throttle PWM to find your feel.
The Black Edition has an improved BEC and larger/remote Cap.
If your running the stock TD body you maybe restricted for space with the BE, so would go with the original VTX10R. I ran the JC body so was able to find somewhere for the larger Cap.
Viper ESC's come pre-soldered and don't forget the 365day warranty
I run the VTX10R-BE and it works great. I run it with a Reedy 6.5 motor and everything runs super smooth a cool
jpas is offline
Old 04-24-2013, 01:11 PM
  #12662
bagged69chevy's Avatar
Trader Rating: 22 (100%+)
has anyone used the molded plastic shock towers yet? any pros or cons?
bagged69chevy is offline
Old 04-24-2013, 07:44 PM
  #12663
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Does the v3 kit come with the +1 degree rear hub option?
Blitzrockey is offline
Old 04-24-2013, 09:10 PM
  #12664
symmetricon's Avatar
Trader Rating: 27 (100%+)
Mine did.
symmetricon is offline
Old 04-25-2013, 12:47 AM
  #12665
Rob Phillips's Avatar
Both zero and plus ones if I remember right...
Rob Phillips is offline
Old 04-25-2013, 05:17 AM
  #12666
Andy63's Avatar
I see many setups containing the 5x1.3mm or 4x1.4mm pistons for the shocks, what pistons are these? and were do i get those? Any of those in the V3 Kit?
I think there was some smaller pistons, but they were so small they didnt fit the Big bore shocks i have.
Thanks for help! // Kind regards
Andy63 is offline
Old 04-25-2013, 08:26 AM
  #12667
mdl060374's Avatar
I think most people drill their own holes into the BB blanks that came with the kit. That was the advice that was given to me and works fine.
mdl060374 is offline
Old 04-25-2013, 08:33 AM
  #12668
tobamiester's Avatar
Trader Rating: 360 (100%+)
if you don't have a set of blanks, use a soldering iron and melt/close 2 holes up. Works like a champ, used same technique on all my 1/10 TD cars.
tobamiester is offline
Old 04-25-2013, 08:46 AM
  #12669
Andy63's Avatar
Thanks for awesome answers!
Then next question, why not use the 6x1.2mm and harder shock oil instead? What is different?
Kind regards//
Andy63 is offline
  #12670
Andy63's Avatar
Kind regards//
Andy63 is offline
Old 04-25-2013, 10:24 AM
  #12671
Kind regards//
read 2.2 damping section: http://home.scarlet.be/~be067749/58/c2/index.htm
nicholasxuu is offline
Old 04-25-2013, 05:23 PM
  #12672
ABBOTT's Avatar
You can not use different my
Numbers of holes or different size holes to equal out each setup has its own properties which can only be explained in a detailed article about shock pack, happy reading!
ABBOTT is offline
Old 04-25-2013, 06:18 PM
  #12673
I use the stock piston and CA a toothpick into the holes that I want to fill, then cut off flush and then add another drop of CA. Works great!
Old 04-26-2013, 01:26 AM
  #12674
Andy63's Avatar
Thanks for great answers! Will try!
// kind regards
Andy63 is offline
Old 04-26-2013, 10:42 AM
  #12675
you don't really need toothpick to do that.
just overfill the hole with CA glue.
detailed tutorial can be found here:
http://losiracing.blogspot.com/2012/...e-pistons.html
