Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
I like Avid for the buy what you need system, and super fast shipping. If you need one size, you can buy just one. I use the one with one seal for the outside and none for the inside, reduces friction.
I ran the basic Avid set for about 14 months and when I felt the car needed new bearings I bout the same set which left it good as new. DIRT CHEAP and excellent quality. Ceramics are better but GD people think they are selling you diamonds. $64 isn't the most expensive price for ceramic bearings but it surely isn't cheap.
Boca Bearings is local to me and I've bought bearings from them for years because they had the correct size fort my paintball triggers, but as small as they are, Boca way overcharges. Luckily I make it up on the overall sale of my triggers, but still, I know how much it costs them to manufacture them and production costs so it bugs me that they mark them up a few hundred % on me.
Thanks for the info Incubus, much appreciated Brudda. I am going to give Acers a go.
Do you know where I can pic up a chassis skin for the V4?
Thank you again my friend
Hey Incubus,
When buying bearings do I want both sides of the bearings to have rubber seals or only I side of the beAring with a rubber shield being the more exposed to debri side.
Thanks Brudda
Thanks Brudda
realistically speaking all you need rubber seals on are the wheel hubs front and rear. Everything else can be open because it sits pretty much sealed and allows oils and greases to pass through and penetrate, thus keeping them well lubricated.
Thanks Incubus much appreciated. I assume bearings without rubber seals are more free rolling do to less friction.
Not particularly. The rubber seals reside over the standard shields which are hardened SS so as long as they are properly lubed they will function just the same.
I've never seen any dirt inside my diffs but it's not a bad idea to get the same rubber sealed type for the outdrives not he transmissions, just in case. That's how I ordered my Avid bearing kit.
motor heat sink or fan
Anyone running a motor fan or heat sink on the motor? Or know of one that will fit with little or no modification?
A low-profile 30mm fan fits perfectly under the front driveshaft. Just use a strip of STRONG servo tape and you're good to go. Mine is a MuchMore fan and has never quit working but there are better, more powerful fans out now.
The one mistake I see made is that many people drill holes in their lids up front but they don't drill hols in the rear so some of the heat remains trapped. I drill 3 holes in front on either side and 3 hole at the rear of the sidepods so as to allow the fresh air coming in flow right on through pulling most of the heat with it.
gearing possibly?
Thanks, I'll try some minor drilling in those locations, thanks a lot for the time and help
Good but still… INSTALL A FAN!
I've had one in every wheeler I'ver run and I have never suffered equipment failure. On the contrary I have seen others suffer failures due to extreme temperatures that cause a multitude of issues ranging from motor death to ESC meltdown.
Better safe than sorry.
